Results 1 to 7 of 7
    Jun 2009
    good pm mga sir!
    question lang po will 16.5x 6.5 rims will fit 185/55/16 tires?
    plan ko kasi magchange ng rims after dumating ng unit ko eh.
    TIA!
    no. rim diameter should be the same as tire inner diameter. so if your tire is 16 inches then your rim should be 16 also. ngayon lang ako nakarinig na 16.5na rims.
    Jun 2009
    Quote Originally Posted by bulldog View Post
    my bad sir 16x6.5 pala ang ibig ko sabihin, will 16x6.5 rims will fit 185/55/16 tires sir?
    mukhang mas kasya dyan ang 195/55/16... imho, masyadong payat yung 185 for a 16 inch rim... actually recommended nga dyan is 205/50/16. yan ang swak na swak.
    teka. anong oto pala? tsaka make sure that the tire offset is within the recommended range. kundi sasayad yung goma mo sa fender.
    Jun 2009
    honda jazz 09 sir. plano ko kasi palitan ng new rims ng stock. so dapat pala pati tires din talaga ipon pa hehe thank you mga sir!
    May 2007
    12.5 tru 16.5 rim diameter are available to any off road truck or hot rod shop, but since tire on this sizes are hard to find those old school rim are becoming more and more un-popular.
    Sep 2009
    If your are looking rim you can email me rohmagwheel*gmail.com
    you can visit www.rohwheels.com
    I'm not dealer ir reseller. I'm the manufacturer. We got some in the Philippines
planning to change my rims.
