Guys, my idea ba kayo kung gano pa katagal magagamit ang 80% tires? or kung ilang KM pa ito magagamit? ikakabit ko sana muna ito sa rims ko for the meantime. safe ba ito?
Thanks...![]()
Thanks...![]()
matagal pa yan bro basta di pa lumalabas yun tread wear indicators/bars.
sa goma, may treadwear indicators. parang tungki yun sa pagitan ng mga treads.
normally, 80% tires, can last around 2-3 years, but it depends on the road that you are travelling, the driving conditions, as well as the driver attitude itself.
so to conclude, you have to check your tire every now and then. depende talaga yan.
ito yun. depende sa gamit din ng auto tsaka treadwear rating and also the type of tires.
Madaming factors para masabi kung ilan km tatagal ang tires. Una ang treadwear rating ng gulong. Inflation. type of road. speed. road temp, among other things.
Sa avanza, I am not at 57,000+ km using the stock tires. hindi pa sumasayad ng indicator, but I think dapat ko ng palitan. siguro nasa 10% to 15% na lang ay sasayad na ang indicator.
Mayroon din "life" ang gulong. Kung kaya, palitan na after 4 years mula sa data of manufacture not date of purchase. dapat palitan na pag 5 years old na. pudpud man o hindi.
Mayroong nagtanong sa akin dati kung ano ang magandang ipalit sa stock na gulong ng Avanza. nasa 80,000+ na daw ang odometer. Service vehicle daw kasi.
[SIZE=3]Assuming that your wheel alignment, camber, and balancing are OK & you are driving responsibly on fairly good roads, 2 to 3 years pa yan.[/SIZE]
[SIZE=3]. . . very true[/SIZE]Originally posted by Meledson
Last edited by jjmd3_787; September 11th, 2009 at 07:01 PM. Reason: tao lang po ...
