Results 1 to 5 of 5
    Mga Bossing ask ko lang what would be the maximum specs of the tire i will be using kung 18inches mags gagamitin ko? yung sa new everest 18inches ba na mags ay magfi-fit din ba sa sportivo ko? considering i will not be using the stock tire of the new everest papalitan ko sya ng above question ko na tire specs including the center caps.
    regards
    235 / 60 / 18 po
    Jun 2007
    Quote Originally Posted by splitfire011978 View Post
    regards
    Stock tire for the Sportivo is 235 / 70 / R15 pwede ka gumamit ng 255 / 50 / R18
    At ang difference lang niya sa stock ay 0.3% (maximum tolerance 3%) bale sa reading ng iyong speedometer ay 60 kph pero actual na takbo mo ay 60.2 kph
    yun lang baka may rubbing na.
    Quote Originally Posted by dekhsamson View Post
    235 / 60 / 18 po
    Sir kung yan ang size 4.1% and deperensya sa stock bale kung reading sa speedo ay 60 kph and actual niya ay 62.5 kph.... delikado sa braking baka di matanya.
    pero pasok kung 235/55/R18 0.8% lang deperensya
    Quote Originally Posted by shakatak70 View Post
    after lang ako sa comfort sir, kung 55, makaldag na, wala namang problema sa braking yun
    235 / 60 / 18 po
    Thanks for the replies mga bosing will try in actual the sizes you mentioned.
Tire Size for my Isuzu SPortivo
