Results 1 to 3 of 3
    Sep 2009
    Mag peps gandang hapon..
    I am planning to buy a set of mags preferably rota wheels kasi medyo mura ata un.. lalo na dito sa may blumentritt.
    ang oto ko is corolla '92.
    Size ng tire: 195x50x15
    ano po bang yung tamang offset para dun? bale 4 holes sya at ung pcd di ko sure kung 100. sabi ng ibang nakausap ko, kapag corolla small body is PCD100 un.
    ung tire sa loob medyo nakadikit na sa shock pero hindi naman sumasayad.
    Any suggestion of model ng Rota para sa oto ko.
    Many thanks po. awaiting your suggestions.
    emorej691977,
    offset is the measurement of the imaginary center line of the rim to the mounting pad.
    Yung PCD naman is the diameter of the bolts.
    Pls refer to the site below for more details:
    http://www.bigcustomwheels.com/rt_specs.jsp
    As to which mags bagay. Mags is a matter of acquired taste. Ikanga "beauty is in the eye of the beholder".
    I hope this helps.
    Take a photo of your car from the side then upload it here: http://www.rotarims.ie/virtual/default.asp
    You can test out Rota's wheel selections to see which looks best with your car.
Mags Rims Offset
