good pm mga sir!
question lang po will 16.5x 6.5 rims will fit 185/55/16 tires?
plan ko kasi magchange ng rims after dumating ng unit ko eh.
TIA!
good pm mga sir!
TIA!
no. rim diameter should be the same as tire inner diameter. so if your tire is 16 inches then your rim should be 16 also. ngayon lang ako nakarinig na 16.5na rims.
mukhang mas kasya dyan ang 195/55/16... imho, masyadong payat yung 185 for a 16 inch rim... actually recommended nga dyan is 205/50/16. yan ang swak na swak.
teka. anong oto pala? tsaka make sure that the tire offset is within the recommended range. kundi sasayad yung goma mo sa fender.
honda jazz 09 sir. plano ko kasi palitan ng new rims ng stock. so dapat pala pati tires din talaga ipon pa hehe thank you mga sir!
If your are looking rim you can email me rohmagwheel*gmail.com
you can visit www.rohwheels.com
I'm not dealer ir reseller. I'm the manufacturer. We got some in the Philippines
