Results 1 to 5 of 5
    Jun 2020
    Hello,
    I would like to ask your opinion on upgrading wheel size from 17" to 20". I found this good deal for an OEM wheel.
    My question is, how will it affect the ride quality? Also, do I need to upgrade my suspension to run 20s?
    This is for a 2011 Fortuner. I'm running stock everything. I've got no issues whatsoever. May bumbulong lang sakin na palitan ko daw
    thanks!
    downsides are:
    1. tires will be more expensive
    2. smaller sidewall will result to a harsher ride(if you plan to use the same diameter tires)
    you can upgrade your suspension to profender or ridemax.. both made by profender in thailand
    Quote Originally Posted by EchoAlphaDelta View Post
    Hello,
    thanks!
    errr,
    i am curious.
    what do you hope to accomplish in shifting from stock to 20 inchers?
    errr,
    i am curious.
    Maganda tingnan.
    Maganda tingnan.
    yespo.
    i suspected as much.
    dilikado talaga yang we-bulong movement...
    magastos!
20" After Market Wheels for Toyota Fortuner -Cons?
