Results 1 to 14 of 14
    Apr 2013
    Hi guys, I bought a 2nd hand vehicle and the rims of the tires were spray painted by the previous owner using Pylox. It now looks old and faded. I am planning on having it repainted or restored when I saw Plasti Dip on Facebook and now I am looking forward to trying it out. I would like to know if I should have to remove the old paint like sanding it or should I just clean it then I can have it painted using Plasti Dip?
    Or should I just bring it to a shop who specializes in restoring rims/mags?
    Thanks in advance for any replies!
    i would bring it to a professional. para mas ok ang trabaho.
    Jun 2013
    Quote Originally Posted by Battousai1 View Post
    same here... would like to try the DIY procedure..
    Bring it to the professionals. Cost starts at around 2k / set.
    If you wanna try to DIY then take a look at this
    http://tsikot.com/forums/mags-rims-w...m-paint-91057/
    :thumbup:
    Aug 2010
    As with most people, I suggest in bringing it to a shop for specialized service -- better service in fact.
    However, simply using Plastidip has no consequence naman so feel free to experiment it if that's your drift. I myself had tried it myself before and I found.. uh.. I suck at it.
    Try to have a smooth surface. You need not sand it naman but if you did, application should be better.
    Apr 2013
    Hi guys! Thanks for the replies, I think I might bring it to a shop and have it restored first then when it is smooth and restored I think I will try Plasti Dip.
    Jan 2009
    Might I suggest another alternative?
    Plast-dip may be a waste of time as they tend to peel off easily. If you want something that would last, powder coat it.
    Apr 2013
    actually that's the purpose/property of plastidip - to be peeled off easily, without damaging the original paint/surface under it. hindi talaga siya pang-matagalan compared to normal car paint. sumikat itong product na ito dahil sa ginagamit nga pang "test", kung bagay ba ang kulay, tapos kung ayaw mo na e easy to peel off agad.
    Jan 2009
    Quote Originally Posted by xagent_orangex View Post
    I actually understand that.
    Let me put it this way... you use Plasti-Dip when you have nice-looking rims to start with, and which you decided a change in color without ruining the finish. But in the case of the TS, it's somewhat apparent that what he has are a set of rims that are no longer in their best shape. Otherwise, the original owner wouldn't have painted over it with Pylox. In which case, you actually want to "re-finish" the rims, so to speak.
    Anyway, it was an alternative. Just sharing what I would do... Powder coat it now and when I get tired with it, I Plasti-Dip them.
    PlastiDip is not a durable paint if you want something that will last a long time. Best is to have it powder-coated for a durable finish.
    One of the best ones around is PROMASTER. Last time I had a set of wheels done with him, it just took a week to be done. You'll need to have the wheels unmounted before dropping it off at his shop in Cubao.
    LINK: Promaster Premium Automotive Wheel Restoration
    Apr 2013
    Thanks for your referral, I might check it out. Do you have any idea how much they charge? I will only be needing them to remove the spray paint on the rim and probably smooth it out or polish a little bit.
How should you change rim colors if it was sprayed with Pylox or ordinary spraypaint?
