Hey guys, newbie here... need some advice... im planning on buying 19-inch wheels for my '07 honda civic... what are the disadvantages in doing this? any input will be appreciated... thanks!![]()
yes, it's that bad. if people riding on 16s and 17s have given up on the ride quality, what else would 19s have?
If you were to display the car in a car show, 19s would be great. Daily driven, you might want to limit yourself to 16s with slightly taller sidewalls for better ride.
to add, it has a high tendency to crack whenever you hit a hole on the road.![]()
35 psi? Try putting 40 psi and filling your tires with water. That's how bad it'll be. Your car will be slower, the wheels will have a tendency to rub on the fenders, fuel economy will go to the crapper and you'll have to go 20 km/h or less over potholes to keep the wheel safe (with the 30-35 series tires fitted to those 19"s, you'll need to).
Oh, and tires for 19" mags cost about two to three times as much as tires for 15s.
19 inch wheel is so cool! specially in the showroom and standstill, but when you use on your daily basis.. its a waste of money.. try to inflate your stock tires with 35psi and test on the road.. you can answer what you feel on that 35psi tires, its the same with 19inch tires..
