Results 41 to 50 of 180
- Apr 2009
- 1,902
August 29th, 2010 08:48 PM #44
*isa1023
ano po yung secreto sa airbox ng esi na pag inalis eh mas maganda ang hatak?
Thanks po!
August 30th, 2010 02:13 PM #45
ano ga mga laguna tsikoteers? musta ga? hehehehehe
papa crave try nyo yung innova na benta ng kuya ne mrs cands?malay mo diba?
- Jul 2010
- 50
August 30th, 2010 05:34 PM #46mga sir any recommended shop for calibration and shop for turbo charger specialist.....mas ok kung tested shop at hindi gaaano pricy. TIA....TIA
engine; 2c turbo
- Apr 2009
- 1,902
September 1st, 2010 07:53 PM #47Actually paps hindi naman talaga siya malupit na secret. Masyado lang talag restrictive ang stock airbox ng ESi kaya naman mas magandang tanggaling yung plastic pipes and everything after the air filter holder. Kelangan tanggalin ang bumper at fender liner to do this.
You'll find out na yung black plastics na yun plus yung reservior vacuum tank (similar to windshield washer tank sa driver side bumber) ay accessories lang at masyadong mabigat. Much worse, sobrang nirerestrict ang airflow.
Remove them all.
Result? Much, much better breathing intake minus the heat lock hassle caused by open cone-type filters like Simota.
What's more, hindi ka na gagastos dahil stock set-up na din ang gamit mo. Less risk pa sa splashing ng tubig pag maulan.
Yun. Medyo matrabaho lang pero worth the sweat.
PS: Nag-Simota muna ko. Nang maasar ako sa heat lock effect ng short-ram (lagi kasi tanghali biyahe ko nun) bumalik ako sa stock airbox. Tinggal ko nalang yung restrictions then yun mas maganda rpm response ko kesa short-ram simota.
Good luck paps.
September 2nd, 2010 12:41 PM #48
*isa1023
ok copy i will try pag may time ako this weekend....thanks a lot!
September 4th, 2010 10:51 PM #49
September 7th, 2010 10:49 PM #50
Hi Laguna Tsikoteers! Galaw galaw baka ma-stroke!:threadmil:dance1:
