Results 1 to 20 of 30
    Production Lexus LF-A
    -www.nagtroc.org
    Video: [ame="http://www.youtube.com/watch?v=-fTfRh0_RQ4"]YouTube - Lexus LF-A production car captured by Chris Gommeren[/ame]
    Jun 2008
    No way! Is it mid-engined?
    EDIT:
    Did a little research and found out it was front mid-engine. Now, what's with all the vents on the rear?
    Quote Originally Posted by roberto_minosa View Post
    EDIT:
    Brake disc venting for cooling maybe?
    In the concept version they said the large intake ducts above the rear wheel wells feed air to the two rear-mounted radiators, then the hot air exist through the two big vents at the rear.
    I assume its the same for the production version.
    Additional pic:
    Jun 2008
    Ooooooh. Nice. Good thing Lexus is now making functional aesthetics. Last time I was disappointed when I read Top Gear's review of the IS-F. They said the 4 tailpipes were fake...yuck.
    LF-A TECHNICAL SPECIFICATIONS
    ENGINE
    Engine Type: 1LR-GSE
    Cylinders/arrangement: V10
    Valve mechanism: 40-valve DOHC
    Displacement: 4,805 cc
    Bore x Stroke: 88.0 x 79.0 mm
    Compression ratio: 12.0:1
    Fuel Injection Type: EFI
    Octane Rating : 95 or higher
    Max. Power: 552 bhp * 8,700 rpm
    Max Torque: 480 Nm * 6,800 rpm
    Max. engine speed: 9,000 rpm
    Exhaust emissions certification: Euro 5
    PERFORMANCE
    0-62 mph (0-100 km/h): 3.7 s
    Max. speed: 202 mph (325 km/h)
    DIMENSIONS
    Overall length: 4,505 mm
    Overall width: 1,895 mm
    Overall height: 1,220 mm
    Wheelbase: 2,605 mm
    Track
    front: 1,580 mm
    rear: 1,570 mm
    Overhang
    front: 940 mm
    rear: 960 mm
    Coefficient of Drag: 0.31 Cd
    Fuel tank capacity: 73 l (16.1 gallons)
    WEIGHTS (kg)
    Kerb weight: 1,480 - 1,580 kg
    Gross vehicle weight: 1,700/1,750 kg
    TRANSMISSION
    Gearbox type: 6-speed Automated Sequential Gearbox
    Front counter gear ratio: 1.259
    Gear ratios
    1st: 3.231
    2nd: 2.188
    3rd: 1.609
    4th: 1.233
    5th: 0.970
    6th: 0.795
    Final drive ratio: 3.417
    Maximum permissible speed
    1st: 52 mph
    2nd: 76 mph
    3rd: 104 mph
    4th: 136 mph
    5th: 172 mph
    6th: -
    BRAKES
    Front: Cross-drilled ventilated discs, 399 x 34 mm
    Rear: Cross-drilled ventilated discs, 360 x 28 mm
    SUSPENSION
    Front: Double wishbone with anti-roll bar
    Rear: Multilink with anti-roll bar
    STEERING
    Steering gear type: Rack and pinion
    Power steering type: Electric
    Ratio: 14.3
    Turns lock to lock: 2.35
    ELECTRICAL SYSTEM
    Battery capacity: 12V-48AH
    Alternator output: 2,640 W
    Starter output: 1.7 kW
    TYRES AND WHEELS
    Wheels
    Front: 20x9.5J BBS alloy
    Rear: 20x11.5J BBS alloy
    Tyres
    Front: 265/35R20 95Y
    Rear: 305/30R20 99Y
    Additional photos:
    The Lexus LFA will be hand-assembled at the Motomachi plant in Toyota City. Only 500 examples will be built, at a maximum rate of 20 per month to ensure the finest build quality and attention to detail. Each V10 engine will be assembled by a single engineer, and will bear his signature as testament to each Lexus LFA's bespoke status.
    The UK launch price for the Lexus LFA is €368,000 (approximately £336,000). Owners can choose from an extensive range of options to personalise their car, including 30 different paint finishes. Certain items of standard equipment can also be removed, such as the audio system, to reduce the car's weight.
    -NetCarShow
    Jun 2006
    $400,000 for a lexus?!?
    but it looks like a budget supercar (i.e., GTR, NSX).
    It doesn't have the wow factor of a carrera gt, ferrari or a lambo.
    Jun 2006
    the four fake tail pipes were on the pre-production car. the production car is actually one exhaust with two exits on each side. in other words it is not a true quad exahaust. however, it sounds much better than the v8 m3 (both stock).
    Very Nice Lexus LF-A.
    Quote Originally Posted by germs View Post
    LFA 1: [ame=http://www.youtube.com/watch?v=wYv3-yiI9Qo]2012 Lexus LFA Revving! - YouTube[/ame]
    LFA 2: [ame=http://www.youtube.com/watch?v=iS3KE26pbFY]LEXUS LFA SLEX RUN - YouTube[/ame]
    LFA 3: [ame=http://www.youtube.com/watch?v=QvePfg44YZc]Lexus LFA Start up and rev - YouTube[/ame]
    So there are now 3... :D
    Dun sa slex run, iwan yung cam car ah, considering R35 yun cam car :what:
    Sent from my GT-P7310 using Tapatalk 2
    Jun 2010
    Haha baka yung driver din may hawak ng camera? :p
    Jul 2013
    Catch the Lexus LFA at Karrera Showroom this weekend | Autoindustriya
    Among the list of activities in the Lexus Roadshow is the appearance of the limited-edition LFA supercar, which will be on display throughout the event. Visitors can get up close and personal to the Lexus' halo model while enjoying a cup of coffee from Gram Coffee Roasters and vibing to the sweet sound of vinyl records courtesy of Satchmi.
