Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    May 2007
    I'm planning to buy a Range Rover Evoque but nag-aalinlangan ako because of the reliability issue na nababasa ko sa mga youtube at facebook comment. I'm ready to throw a 5m sa Evoque because I think it's the best car sa preference ko: Crossover, AWD/4wd, Can go offroading. Back-up ko si Subaru Forester just in case talagang sirain base sa mga sasabihin nyo. Also lakas maka Yoon Se-ri. Is there a legit Range Rover owners here and can you share inputs what happened after 1 year or after 50,000 may naging major issue na sa sasakyan nyo? I own 5 cars and NONE of them nagkaroon ng major issue or tumirik even at 100,000km. Ni di ko pa nakitang umilaw Check engine indicator sa mga sasakyan ko. Kinakatakot ko kasi baka itirik ako sa bundok at baka maya't maya check engine gaya ng nabasa ko na kakalabas lang sa Casa at 1 day pa lang humina na humatak Rover nya. May nabasa rin ako na sa almost every Check engine ang mga Rovers. Kindly enlighten me. Iba kasi ung manggagaling sa Legit Range Rover owners. Honest to goodness pa share ng mga bad experience nyo sa sasakyan. For Long term everyday use with slight offroading.
    Quote Originally Posted by masterjoe619 View Post
    Good luck, sir![emoji120]
    Mar 2013
    For 5M pesos...get the Landcruiser. Cant go wrong with it.
    Sent from my SM-N975F using Tsikot Forums mobile app
    With 5M, you can buy a new Expedition at a 1M discount (3.5M) and you can save that 1.5M for some other stuff. Or you can opt for what EQ suggested, a Toyota LC200 for less than 5M.
    If you want something smaller than an Exped or LC200, you can check out the Explorer or CX9.
    May 2007
    Too big not my type that's why my 2nd choice is a Forester then lift it then change it the tires to AT. Jimny is too small, ni porrtable ref di kakasya sa loob unless itutupi mo mga upuan. Expedition is too big. I just want a compact 4x4/SUV
    I'll check the Offroad performance of Explorer
    CX9 can't go mud trailing.
    Still wating for Legit Rover owners reply.
    7 seater pala ang Explorer and shitty in Off roading so meh...
    Well, if only the Forester XT is still offered new but you can check for used ones with low mileage. Maybe you can consider a Audi Q5 or a BMW X3 since you have a big budget.
    You can also check out the Outback. It is not a compact utility vehicle (CUV) but it is not much bigger than the Forester.
    Jun 2011
    Jun 2013
    What about the FJ cruiser? We have one and tried to go moderate offroading. Very capable even in stock but we changed the tires to AT BF goodrich. Not terribly difficult to park too since its quite short, unlike the damn Ranger I used to drive. Suprisingly the FJ can go pretty fast in the highways too.
    Mar 2013
    221 Pajero GLS 3.8L Gas, AT, 4x4, Sport Gold Edition. Dubai version. – Cars & Trucks – Quezon City, Philippines | Facebook Marketplace
    How about that? 3 door v6 Pajero 2021. 3M.
    Will last forever. Proven Paris Dakar winner.
    A little long in the tooth but all reliability issues sorted out.
    Mar 2013
    Or..if you want a small light offroader...
    Get the John Cooper works Mini Cooper Countryman . Its 305 HP. ALL wheel drive. A true fire cracker, head turner and smile generator. As big as the evoque.
    4.5m but i think there is a small discount. And unlike the Evoque...this one is a real head turner.
    Evoque...is the entry level range rover.
    Countryman John Cooper Works is the top dog, apex predator Mini cooper.
    Sep 2009
    We had a lot of issues with a 2017 Evoque. Had a defective module after a few months, may pumapasok na tubig sa loob pag umuulan, experienced also the check engine light.
    Ang sama pa ng response ng old dealer. So far maganda after sales ng new dealer. But generally I think it is the car.
    But overall, we cannot recommend it. Unless the new model is better.
    I will go with the advice of the others specially if offroading mo gagamitin.
    How about a used Geländewagen, sir?[emoji4]
    May 2007
    Can't fit a portable ref sa likod maliit. That's why wala si listahan ko si Jimny. Anyway thanks sa mga suggestion nyo. Highly appreciated and pinapanood ko sa youtube mga kotse na sinusuggest nyo.
    May 2007
    Quote Originally Posted by bxr monkey View Post
    Will check the Cherokee. Although sabi hindi daw reliable but I think kaya madalas masira grabe naman iharabas ang mga Jeep. Bakbakan kung bakbakan sa trail.
    FJ is too big with outdated interior.
    Might check the Countryman kung reliable. Importante hindi ako itirik sa bundok at di ko dadalin sa service center maya't-maya
    Jun 2013
    The FJ is not too big. It's barely even wider than the Range Rover you were looking at. The length is similar to most crossovers.
    Agree with interior, but since its geared towards off-roading than luxury, a plain old school interior seems tolerable and would probably be more resistant to wear.
    How about the Jeep Wrangler Sport? I think it’s around 3.5M to 4M. It is powered by a 2.0L turbo gas engine. Wranglers do come standard with a 4WD transfer case.
    The FJ Cruiser is big. It is about as wide as the standard Range Rover. TS is more looking for something smaller like the Range Rover Evoque which is smaller than a CRV or Forester.
    Jun 2013
    Range Rover Evoque Dimensions 22 | CarsGuide
    Toyota FJ Cruiser Dimensions 217 | CarsGuide
    Range Rover Evoque vs FJ Cruiser's dimensions. Evoque is wider than the FJ but the FJ is longer by more than 300mm only. It's up to TC if he considers 300mm or so big since he's also looking for cars which are somewhat reliable.
    Mar 2013
    Jeep wrangler. Egan has a good suggestion.
    Modern
    End of the world apocalypse ready
    Reliable
    Lifestyle vehicle
    Looker
    New model
    Definitely within budget
    Legendary capability
    MINIs & reliable are 2 words that seldom go together. Have worked on some. The gen3s are pure Bimmers now, better than the migraine-inducing gen2s.
Range Rover Evoque Reliability
