Results 1 to 5 of 5
    Hi Peeps,
    I'm looking for a good Kia Carnival mechanic who can do home-service, preferably within my living place in Binan. I suspect either my water pump is faulty or it needs top-overhaul anew (2nd time in 2years), as I just noticed that water drips everytime engine runs.
    My ride is 2001 Kia Carnival AT.
    Tia.
    Aug 2016
    hi good pm po... may Kia Sephia po ako... kinakapos po kpg tumatapak ako sa gas... bago n spark plug, ignition coil, engine oil... paano po mllman kung sira ang high-tension wires?
    Feb 2009
    Quote Originally Posted by hinlog View Post
    Hi Peeps,
    Tia.
    slow down. do not make an engine overhaul procedure on the top of the list in your mind.
    have a cooling system pressure test performed first.
    you do not want to hear of a doctor who would prescribe an open heart surgery without doing the basic diagnosis first.
    it is at 15 years service life already but you mentioned about two "top overhauls in two years". stay away from the "mechanic". look for a competent. experienced and trained technician
    Resurrecting this older thread.. Am also looking in the same general area. Did you have any luck?
    Sent from my HUAWEI P7-L10 using Tapatalk
    Quote Originally Posted by paulricz11 View Post
    Di kaya madumi na FUEL filter
Kia Mechanic
