Results 1 to 7 of 7
Tsikot Member Rank 3
- Dec 2002
- 636
July 11th, 2004 09:54 PM #1The aug issue of 4x4 Australia reviewed the used jackaroo/trooper models from 98 using the 3L 4JX1 engine. I'd like to quote some interesting points:
1) The caterpillar HEUI system relies on oil pressure to run the injection. By 70k km, many of these holdens were hit by troubles, beginning with leaking O-ring seals for the injectors. Caterpillar provided revised O-rings for isuzu to retro-fit, and in most cases it seemed to work.
Bottom line: anything built before Nov 3, 1999, was subject to a recall to fix it, so make sure this has been done.
2) The type of oil used is crucial, too. The injection needs low-viscosity oil to pressurize properly, especially when the engine's cold, so the recommended 5w-30 or 5w-40 synthetic is not negotiable. The wrong oil not only makes the jackaroo hard to start, but may lead to O-ring problems.
3) To compound the Holden's injection issues, the engine isn't very tolerant of bad diesel fuel. It can get smoky, lose performance and suffer seal failures- all the things that became difficult for subsequent high-tech diesels when they encountered our crook fuel in australia.
Tsikot Member Rank 5
- 3,144
July 11th, 2004 10:06 PM #2jackaroo,
We're safe, 2000 models na tayo and matic tranny na. Most casa horror stories (inteco QA) are those pre-2000 4JX1 models with manual tranny.
- 3,144
- Dec 2002
- 636
July 11th, 2004 10:21 PM #4Also glad we have biodiesel for our engines. The better lubricity of coco diesel may help lengthen the life of our injector seals.
Do you think we can order o-ring seals from the local caterpillar distributor instead of isuzu?
- 3,144
July 11th, 2004 10:57 PM #5that biodiesel, thanks for reminding... tawagan ko nga si garyq..
o-ring seals -- we need the specs, I'll ask if I can...
July 13th, 2004 06:52 PM #6
wala bang adverse effect yung biodiesel sa mga injection pump and fuel delivery systems?
- Dec 2002
- 636
July 13th, 2004 10:58 PM #7mbt,
So far biodiesel has improved performance, smoother engine- guess lubricity claims actually work.
Try it before price goes thru the roof!
Latest mileage:
