Results 1 to 3 of 3
    Hello Guys do you n=know of any shop that could check on my rides 4x4 as I am running I press the 4WD switch I hear the actuator working but the 4x4 does not engage on shop i brought it into said it might be in the defferential because the shaft and propellers are working hoever they don't have much experience on isuzu's
    99 troopers are vacuum activated, the best way to confirm is to check the vacuum lines.
    Nov 2007
    Hi Mon,
    That's true with the '97,right? Good to have a more appropriate thread. I remember you upgraded from a 97 to a 99,right? What is the difference performance wise between the two?
    TIA
99 Isuzu Tropper 4X4 M/T
