Results 1 to 4 of 4
    Sep 2009
    Elow po! Mga master, may tanong po ako...
    Yesterday mga 7:21am habang nakaparada ako sa gawing retiro nanonood sa pulubi na nakabukaka, nasira "ata" yung relay flasher nitong xto ko kasi nung sinindi ko yung hazards ayaw na gumana. Instead na tik...tik...tik... yung naririnig ko, tssssssskkk lang at wala ng signal ng hazard pati sa dashboard.
    Though yung signals ng left and right naman gumagana.
    Hanggang sa... ginamit ko yung busina at sa laking gulat ko, pati ito ayaw ng gumana.
    Ang tanong ko po eh ang nasira po kaya yung relay flasher ko? Dito kasi galing yung tsssssssskkk and may kuneksyon ba ito sa pagakawala ng aking busina? Sakto at sabay nawala eh.
    At may replacement ba para dito kahit hindi DENSO? Mahal eh.
    Sana may makatulong sakin at alam niyo naman diba na mahirap gayahin ang tunog ng busina ng ating xwind. Masakit at kumplikado sa lalamunan.
    Salamat po sa mga tutugon!
    Quote Originally Posted by holdencaulfield View Post
    bakit naman kayo nanonood ng pulubing naka-bukaka, this early?
    ako naman, nanood ako dati ng pulubing ibinaba ng chedeng diyan sa may cubao (true!).
    seriously.. i don't have a crosswind. but if no crosswind aficionado comes to the rescue...
    dalhin nyo po sa nearby banawe fixit shops. go to one who actually has a physical shop/store with parking, and not the itinerant mechanic. they should know where that darn flasher relay is. it's a relatively cheap item.
    but... somehow, i don't think it's the flasher. dahil may damay na iba, baka fuse or wiring.
    if you are so inclined, check your fuses in the fusebox.
    good luck.
    Sep 2009
    bakit naman kayo nanonood ng pulubing naka-bukaka?
    ako naman, nanood ako dati ng pulubing ibinana ng chedeng diyan sa may cubao (true!).
    good luck.
    Thanks doc! I found the relay flasher po. Good po coz it's just under the area of the steering column and above the pedals. This is where the sound is coming from. For that tiny relay, 1600 po ang Denso.
    mahal PALA!
    puede kaya yung aluminum-bodied relay? it's much cheaper.
Crosswind relay flasher
