Results 1 to 20 of 26
    May 2009
    hello do you use 1st gear sa arangkada on your crosswind or any izusu vehicle? kasi ako nasanay na ako using 2nd gear sa arangkada timpla lang ng konti sa clutch oks na. By the way magisa lang kasi ako palagi sa ride ko na crosswind and matagal ko na din naman ginagawa ito and wala naman ako nararamdaman or nasisirang part related to it........meron kayang effect ito sa clutch or any system connected to it in the long run? share your toughts naman...thanks
    Apr 2009
    Quote Originally Posted by jaz014 View Post
    i used to do this sa adventure namin, arangkada sa 2nd gear, basta hindi fully loaded yung vehicle. almost all diesels have this ability because of the available low-end torque. though now i refrain from doing it kasi it will shorten the clutch life.
    peace.
    Feb 2005
    Can be but I would suggest/discourage doing so to avoid adding stress to the tranny.
    Yup,- parang jeepney driver style iyan... :grin;
    12.1K:drunk:
    Sep 2005
    Aguy 2nd gear sa arangkada.
    Jul 2003
    Quote Originally Posted by garfield_08 View Post
    peace.
    it won't affect the clutch. the effect is more on the gears inside the tranny.
    Apr 2009
    Quote Originally Posted by fourtheboys96 View Post
    yup, i stand corrected. thanks.
    peace.
    Jan 2011
    walang masisira na part sa tranny saka sa clutch. mabagal lang ang arangkada at hindi susundot pag tinapakan mo yung gas di tulad sa 1st gear. Kahit automatic transmission pwede mong pagstart sa 2nd gear. sa mga countries na may snow makikita mo sa car manual na start yung gear sa 2nd para di magslide yung gulong so okay lang yan.
    It will affect the clutch (disc) in a way from premature wear. Use the 1st gear that's why it's there hehe.
    Oct 2009
    mas maganda pa din if you use first gear. that has a purpose why its there. altho dati sa pickup kong diesel palagi din akong 2nd gear. :D pero parang masama.
    Wala akong isuzu, pero sa corolla, no. :hysterical:
    1st gear from stop tapos shift to 2nd gear ... bira na. :naughty2:
    Feb 2011
    OO.. isuzu fuego 1999 yung model... medyo may sira yung sasakyan kaya hindi siguro kaya na.. pero nung bago pa sya eh kaya mag umpisa sa 2nd gear ang arangkada pero ngayun eh talagang 1st gear muna pag aarangkada... actually sanay ako na mag start ng arangkada sa 2nd gear dati pa kase yung diesel na L300 van na early 90's at nissan patrol na early 2000's eh kayang kaya na umarangkada ng 2nd gear.. lalu na yung L300 na matagal na eh sisiw ang arangkada sa 2nd gear perong itung isuzu ko na fuego eh talagang dapat 1st gear arangkada, kung hindi eh mamatayan ako hehe
    Nov 2007
    Before, I use second gear on our Mitsubishi Adventure or L-300 van both diesel, it won't affect the tranny so long as your load is light, if heavy load then use the first gear for a few seconds before shifting to second.
    not always, pag kaya lang ng sasakyan at medyo palusong ang daan.
    otherwise primera pa rin, para less wear sa C-Disc
