Results 1 to 11 of 11
    this pertains to my xto 02. pag nakatigil, ang tigas ng steering, hirap talaga ikotin ng manibela. mas matigas pa sa manual. sabi ng mekaniko, idler arm. pinalitan na, ganon parin. pinalitan na ang hose baka may leaking daw, ganon pa rin. sabi ng mekaniko, steering box na ang palitan. i paused for a while and decided to ask the gurus here. maybe you had same experience before. ano kaya talaga ito?thanks for any help.
    Feb 2005
    Quote Originally Posted by chantee View Post
    At that vehicle age (2002), it would be logical if some steering problems may already be experienced. But before doing additional major expense, best to check if the hydraulic steering pressure is still right.
    Now the equipment needed to measure this may only be available sa CASA. If you could bring your unit to an Ayala dealer (Alabang, Pasig or Cavite), they may have this gadget.
    Hope this helps.
    yup. thanks so much for the advise. ill do this today.
    Jan 2010
    nung nangyari sa akin to ang problema e yung compressor / PS belt. Pinalitan lang ng bago at umayos na sya.
    Mali yung size na naikabit nung una kong mekaniko... nung nakabili ako ng replacement sa Jaysons gumaan na ulit yung manibela.
    Aug 2010
    pardon my ignorance but, saan ba makikita yung lalagyanan ng power steering fluid ng sportivo?
    Feb 2010
    Quote Originally Posted by theonlyone View Post
    may pangalan naman sa takip, tingnan mo lang yung naka-indicate na pangalan, mostly left side near in front of the engine compartment, or sundan mo yung mga hose na naka-attached sa steering gear box.
    check mo din sir ang gulong mo baka kulang hangin at ang alignment sobra toe in o toe out isang cause din yun ng ng medyo pagbigat ng manibela.at isa pang pwedeng dahilan ay baka nagpalit ka ng mas malapad na gulong bibigat talaga ang manibela ito rin kasi nangyari sa fuego nmin nung nagpalit kami malaki at malapad na gulong bumigat talaga ang manibela. hope to help
    + 1 sa belt baka dun lang culprit naexperince ko sa fuego namin dati mabigat manibela pag nililiko umiingay pag nasasagad ang liko.pinalitan ng belt medyo lumambot ang manibela hope to help
steering problem, matigas
