Madami ako nakikita na mga earlier model ng crosswind xuv and xuvi na wala na yung stainless plate sa harap, yung sa akin nagkaganito din, ano po ang ginawa nyong solution para dito? tnx
I had this problem also what I did was that I applied devcon steel epoxy. Iniwan ko lang overnight na dumikit yung plate sa plastic bumper then kinabukasan hayun super dikit na. Its been two years na at so far hindi naman natatanggal ang plate. IMHO, parang forever nang didikit yung plate. Heat-resistant at all-weather yata itong epoxy na 'to. Try mo rin pre and I'm sure solve ang problema mo
As dok_vin already mentioned, permanent countermeasure is to apply epoxy or Hamatite. If cured as instructed, that metal plate will be in partner with the overrider FOREVER!
