Results 1 to 10 of 18
June 14th, 2010 11:10 AM #1
Hi mga paps. may available ba fogl lights ng crosswind (XUV2003) na projector type? or kahit modified? lagi kasi dumudumi loob nung stock na H3 fog lights...
medyo mahina din sa ulan... kung HID ba hindi kaya prone to water damage naman? kasi lagi tilansik ng gulong. any suggestions?
June 14th, 2010 12:44 PM #2
[QUOTE=Torque Master;1494447]Hi mga paps. may available ba fogl lights ng crosswind (XUV2003) na projector type? or kahit modified? lagi kasi dumudumi loob nung stock na H3 fog lights... Wala, unless aftermarket (thou i have yet to see one)
medyo mahina din sa ulan... kung HID ba hindi kaya prone to water damage naman? kasi lagi tilansik ng gulong. any suggestions? I have tried installing HIDs on my '03 XUVi unit before... ok naman kaso kung masyadong puti (8000k-higher) wala din silbi sa basang daan. From my knowledge, yan ang problema sa mga pre-2005 Crosswind foglights, pero should you decide to install HIDs, you need not have to worry na mababasa bulb or interior of the foglamp, sealed naman likod nun . Just make sure you lock it's cover when you so decide to replace the stock bulb.
June 15th, 2010 02:49 PM #3
[quote=Benzmizer;1494533]di kaya malusaw yung housing ng fog lamp pag sobra lakas na HID?
yung ibang fog lights, nag fo fog sa loob pagnababasa ng ulan :D no wonder they call it fog lights :D - may breather valve kasi yun sa likod na pinapasok yata ng moisture minsan. yun iba naman, nagmimistulang fishbowl, napupuno ng tubig ulan hehehe
June 15th, 2010 03:05 PM #4
June 15th, 2010 03:21 PM #5
designed naman kasi na medyo sabog / flood ang fog lights kaya nga mababa ang location niya. not ideal to have it retrofitted. all weather type ang maganda ikabit sa fogs para tagos sa ulan and baha - kitang kita mo pag umaalon :boat: for less than 1K /pair pwede mo palitan kahit every year
June 19th, 2010 12:41 PM #6
naka HID rin ako headlight at foglight, 8000k lahat. mas better if ung foglights kay 3000k ang color para makita ung road, kasi di masyado makita if 8000k ang foglights.
June 20th, 2010 10:39 AM #7
mga bro, ask ko lang kung magkano at saan nakakabili ng fog lamps for crosswind 2003. pinapasok na kasi ng tubig sakin at tunaw na yung reflector. meron ba kayo alam? thanks
June 20th, 2010 09:16 PM #8
- Jan 2006
- 28
June 21st, 2010 08:56 PM #9good day... may available na po kayang foglamps for 2010 crosswind xt, mas malaki po ang diameter nya compare sa earlier models eh, gusto ko sana yung fit na fit sa mounting as in parang oem foglamps na, thanks po sa magre-reply...
June 26th, 2010 12:34 PM #10
Ask ko lang kung magkano pala ang foglights ng 2001 crosswind. may nakita ako dito sa cebu na tag P2k ung 1 side.. magkano pala ang set?
Traffic!
