Results 1 to 11 of 11
    Jun 2005
    patulong naman po... had my 80k km PMS sa casa, advise nila to replace
    1. steering center link assy
    2. idler arm assy
    3. tie rode ends LH/RH, inner/outer
    quote is around 29k... san ba shop na pede makabili ng replacement parts at shop na rin na pede gumawa... thanks
    XT nga pala yung model ng crosswind
    Dec 2003
    marami sa banawe tol, hanap ka dun mga brand 555, federal mogul etc. marami yan la pa ata 10k lahat pag dun ka bumili
    Get replacement parts na 555 brand (just make sure na orig as may fake na rin na ganito daw) for the tie rod and center link. For the tie rods, you can also try having Zee refurbish it at a lesser cost (then have your balljoints done na rin para swak). ;)
  4. jagxtrm Guest
    check out walco sa banawe malapit sa e. rodriguez...
    or yng jayson auto supply sa binondo...
    both shops only sell, u need to contact ur suking mekaniko para ikabit.
    Sep 2004
    Quote Originally Posted by semis_planr
    2. idler arm assy
    pare, puede mo ba bigay sa kin yung breakdown ng prices? particularly the centerlink. kahit pm mo na lang.
    galing ako sa servitek and kailangan na rin daw palitan yun. quote nila is 4850. 555 yung ipapalit. di ko pa napagawa, naubos pera ko sa gulong.
    Jun 2005
    bluebimmer,vinj, jagxtrm - thanks for the replies guys...
    semis...
    bat nila nasabi na palitin na yung parts na yun? malikot ba steering mo? uneven ba tyre wear mo? ako kasi, more than 100K KM na, di pa rin ako nagpapalit nung parts na nilista mo, although I'll admit, di ko na sa kasa pinapacheck xto ko after my 50K KM pms. Nung last time nag align ako sa Servitek, they usually check those parts first before doing an alignment job and they did'nt find anything wrong. palagay ko pa check mo na lang sa labas muna before changing any of those steering parts. Malay mo di pa naman kailangan palitan. alam mo naman ang casa, sa parts yan humahataw ng singil minsan.
    If you really need to have those parts replaced, nirefer sakin isuzuautoparts, sa may caloocan yata yan. hanapin mo na lang sa directory.
    What I did replace was my clutch disc/pressure plate including pilot bearing. Nag clutch slipping na kasi ako after 90K km.
    have to agree with rsnald bro. kuha ka muna second opinion. lam mo naman sa casa, konting diprensya lang, palita pyesa kaagad.
    Mar 2005
    I agree with sir rsnald. Take your Crosswind to Servitek for a second opinion. Karaniwan racket lang yang recommendation ng mga casa. If you really need to buy replacement parts and if you are near Cubao, go to G. Fernando's along Aurora ave. Their Isuzu parts are cheaper than Walco's of Banawe. If you need original parts, you can go to Walco. Dito kumukuha ng parts ang Inteco.
    Sep 2008
    Quote Originally Posted by Hibiki View Post
    Hibiki,
    Saan located ang G. Fernando's? Mahaba kc ang Aurora Ave. thanks in advance.
    Apr 2009
    Quote Originally Posted by semis_planr View Post
    2. idler arm assy
    pare meron kme nyn mga gnyan parts ng crosswind if u like just contact me in this no. 495-80-38 or just txt me nlng 09052133771 mura lng po mgnda pa yung mga parts...
isuzu crosswind replacement parts
