Results 1 to 11 of 11
    Nov 2006
    [SIZE=3]hello po, i'm from baguio and i'm planning to buy a local Isuzu Trooper... i'm willing to add a little kung sariwa yung unit and higher year model
    i need your help 'coz i don't know how to differentiate a local unit from an imported one.. what signs should i look for?
    what year model do you recommed? what engine is best? i'm having
    second thoughts coz i've read in other threads of the Trooper's injectors??
    anyway, i think i'll still go for a Trooper..need your HELP po.. tnx
    rosy cheeks
    [/SIZE]
    Sep 2004
    Quote Originally Posted by rosy cheeks View Post
    rosy cheeks
    [/SIZE]
    one way to find out if local is to check the registration...next all local trooper's antenna is on the right side, while Japan surplus is on the left side.
    just get any trooper that doesn't have the 4jx1 engine.
    good luck
    rosy cheeks,
    I'm from baguio also. I'm planning to sell my trooper....it's an original LHD 1996 model, with a 2.0L 4-cylinder gas engine.
    rosy cheeks
    [/SIZE]
    Ideally a 4jg2-tc is the better engine pocket wise, A 99 trooper is the year and model that is sought after, simply because it has the newer(or the last) face and it has the old reliable non electronic engine and it comes only in a simple M/T.
    Mas panatag ang loob mo kapag 4jg2-tc ang makina ng Trooper na kinuha mo. Kasi karamihan talaga ng 4JX1 ay may defective na makina. Kami nalang yata ni Redhorse ang may Trooper na hindi defective ang makina. 4JX1 na yung saken.
    Aug 2007
    looking for trooper steering wheel. yung 98 model up. thanks
    Quote Originally Posted by janrye26 View Post
    I suggest a brandnew steering wheel because 2nd hand is prone to wear. If you can find one you can also get the leather replace/re upholstered.
    sir 4jg
    anung displacement ng 4gj2 na engine?
    Aug 2007
    Quote Originally Posted by 4JGtootsie View Post
    sir, san kaya makakuha ng brandnew?
    rosy cheeks
    [/SIZE]
    sir check nyo rin headlights and side mirrors ..
    iba ang light patter ng RHD sa LHD ..
    -/- -/- ang sa LHD while -\- -\- naman ang sa RHD .. (low beams po)
HELP!! re: Isuzu Trooper
