Results 1 to 10 of 3710
    Aug 2009
    [quote=red16;1689129] Gud eve... mga sir! Kapapa ayos kulang ng leak sa radiator ng a/t 02 xwind namin. After na fix yung radiator, pina start at binomba or pedal to the gas ginawa namin pra malaman kung may tumutolo pa. Ok na cya at wala ng leak kaso nung tumatakbo nko at nag miminor bigla nalang namatay yung makina.. 3 times nang yari sakin. Binalikan ko yung shop at pina check ko ulit yung pinag kabitan ng mga pipes sa radiator eh.. ok naman at walang tagas or maluwag. Pina check kurin ang Battery, ok din (9months old) Hindi ko alam kung ano ang problem ng "Engine" bakit namamatayan ako. 1 year & 8 months plang yung xwind nang mabili nmin.
    Pcencya na mga sir... Na repair nanamin yung culprit ng fuel line.. May kunting tagas kaya pala namamatay yung makina kapag nag miminor. So far ok na ulit kunting sikip at "teplon" tape ayos na ang tagas. hehehe...
    Mar 2011
    noobie here. tanong ko lang kung meron kayo alam gumagawa hid retrofits for 2004 xuvi crosswind. TIA
    Jul 2010
    Quote Originally Posted by mjuane View Post
    You can PM garyq or visit his site: www.hidretrofit.net
    Sep 2010
    Guys,
    I have 2007 XT. I am not sure when do I change to new tires. It is still using the original tires. It's been 4 years, but still ok.
    For safety purposes, I hope you can help me when to change these old tires to new ones.
    Thanks
    -Noel
    Quote Originally Posted by noelbranz View Post
    Guys,
    Thanks
    -Noel
    posting the digits of your odometer will help people to give you good advise for this
    Sep 2010
    Quote Originally Posted by kaioz View Post
    its KM is at 61K
    Feb 2005
    Guys,
    Thanks
    -Noel
    Here are signs that you need to be aware of:
    Tire Wear Indicators
    * The simplest is when you can see how thin the tread of the tire is. If the state is almost paper-thin, then it’s time to get a new one.
    * Look for the tire wear indicators. These are small bars in between the threads. General rule of thumb is, if you see three or more of the indicators, then better change up.
    * When you see lumps and bumps on the tire
    * When you experience slipping and decreased handling. One cause of this could also be due to poor alignment causing uneven wear.
    These are some of the symptoms you have to look at when it comes to replacing your tires.
    Sep 2010
    Quote Originally Posted by Benzmizer View Post
    Thanks Much!
    Jul 2010
    Well said & illustrated Benz. You should be paid by tsikot for answering our queries.. Hehehe..
Isuzu Crosswind Owners Thread [continued]
