Results 1 to 18 of 18
    Jun 2009
    just replaced the busted stock h4 bulb of my hilander with an all weather bulb this evening.
    my question is, how do i adjust the aim of the headlight? i can't seem to find the adjuster. unlike my sentra the adjuster is very visible.
    tia
    Aug 2005
    If you replaced a halogen H4 bulb with another halogen H4, there should be no difference in the aim. Regardless of brand.
    Feb 2005
    I agree. Changing the bulbs should not alter the aim of the headlamps.
    Quote Originally Posted by ramledi View Post
    tia
    What model of the Hilander do you have?
    Jun 2009
    its a 2001 hilander sl
    found it already hehehe
    i've installed the bulb around 9pm maybe that's why i missed it lol
    thanks for the reply anyway
    Sep 2009
    sirs bakit pag naka low-beam ako masyadong di ko nakikita yung ilaw?
    halos parang di nakasindi so i switch the fog lamps for better view.
    normal ba ito sa crosswind xto?
    TIA!
    Feb 2005
    Quote Originally Posted by holdencaulfield View Post
    TIA!
    No. Check:
    • Headlight aiming
    • Bulbs. One may already be busted. (Remember, H4 ang bulbs kaya combined ang Hi and Low beam. One may already be shot)
    • Headlights may already need cleaning
    Feb 2005
    Since we are in topic, let me share to Crosswind 2005~ owners how to adjust your respective headlights:
    Hope this helps.
    Oct 2009
    TIA!
    sir same case with mine. pero yung akin i think busted ung pang low beam.
    mga sirs, san po ba nakakabili ng quality but not so expensive bulb at anong brand ang maganda?
    thanks
    Feb 2005
    sir benzmizer thanks alot! i'll try to follow the manual, very helpful indeed!
    sir btw, what is the ideal wattage if i should replace the bulbs?
    sorry i have no idea and i prefer sana the "stock" wattage lang para iwas complications. and aside from osram are there any other brands that you can suggest and that can bring out enough light without harming the casings or electricals? and hehe price din sana.
    thanks!
    The standard (stock) bulb wattage of a Crosswind is 55/60. Either of Philips, OSRAM brands are reliable.
    One alternative you could do so you need not have to worry of damaging your wiring harness is to use CERAMIC BULB SOCKETS. I think it's around 1,200-1,500. That includes 2 ceramic sockets, wiring harness and relays. You can then use 90/100 bulbs after installing this without worries.
    Quote Originally Posted by Jaborro2 View Post
    thanks
    Philips or OSRAM brand comes into mind. Any auto supply has these. These are normally the brands manufacturers use as OEM bulbs.
Headlight Aiming
