[SIZE=4]gusto ko sana mapalakas ung headlights ko e.[/SIZE]
[SIZE=4]this week i will buy allweather bulb na xenon...[/SIZE]
[SIZE=4]lalakas kaya ung ilaw ko? sabi kc ng frend ko bumili daw me ng xenon na bulb tig 500php ang isa...[/SIZE]
robz, please bawal po ang text speak dito sa forumi've already reminded you in your other thread.
importante na malinis ang loob ng lens at reflector mo kasi kung marumi ay magiging useless kahit higher wattage or mamahalin pa ilagay mo. basta palagyan mo ng relay at siguradong maayos at mahigpit ang grounding.
Its not ok to put Xenon bulbs, because of your reflector type.
Why not try Osram Silverstars..yun 50% more light. While you're at it, pa linis mo headlights mo.
Does your windshield have tint? It helps if you remove it.
parang xenon bulb din ba yung osram na yun?
kasi yung pick up ko wala pang foglamp,
wala pa me pera pambili ng foglamp para sa pick up ko na 93 model...
my binebenta sa akin sa banawe 1500php na foglamp kaso taiwan ang tatak. hindi ko alam kung compatible ba sa lagayan nun...
IMO, you actually don't need them fog lamps for ordinary night time driving, i would agree with sir xto, just make sure malinis, and yes, removing the tint on your windshield if you have one is a big help, or just put one with the neutral shade
what i did with my LS was to get a pair of bosch headlight frames to house my then all weather narva H4, which i downgraded to just the regular ones as the former's use were only maximized whenever it rained, and were most expensive, so just the regular 100watts ones are good enough for me and they're doing just fine now, still a big improvement from the stock 55watts of lighting my sealed beam used to provide me. it's brighter than another new stock pickup that we have.
HTH
Warning for thread starter robz02 for using text speak in his posts. Read the forum rules and regulations.
Also use the Search Function. This topic has an existing thread for reference:
http://tsikot.yehey.com/forums/showthread.php?t=20763
closing thread.
