Results 1 to 3 of 3
    Jan 2010
    Hi everyone, newbie here!
    Sorry po mga regular members (I hope I also become a regular member), my problem is this
    My ride is Isuzu hilander 97 SL model, i think there is something wrong with my clutch master or slave cylinder or maybe clutch assembly. Kasi sobrang lalim ng clutch pedal. kapag nag shift gear ka, dapat sagad un clutch pedal mo sa flooring before you can shift gear and of course released mo lang konti un pedal forward na hilander ko.
    Hassle kc sa trapik, nakakapagod sa legs.
    I already replaced the clutch master cylinder(japan replacement), slave kit(orig) pero ganun pa din.
    Any suggestion or comment of Hilander owners is highly appreciated. thanks
    Good day sir, na-experience ko rin yung ganyan sa ride ko due to worn out clutch repair kit (master and slave). Had it replaced at balik na sa normal pero sabi mo na-replace mo na rin. Baka po kulang lang sa bleeding, nangyari na rin sa akin yung ganyan dati, bagong replace lang yung master at slave pero ang lalim nung clutch ko tapos konting angat lang, andar na agad yung sasakyan, pina-bleed ko lang ulit sa mekaniko ko at umayos na rin. Sana po nakatulong
    Jan 2010
    Quote Originally Posted by DieselDI View Post
    thanks sa reply sir, will try your suggestion, though sabi ng mechanic kung meron daw air sa clutch fluid system somehow it will be quite difficult to shift gears. anyway I will take your advise na din wala naman mawawala eh. frustrating lang kc after replacing the clutch assembly(release bearing,pressure plate,pilot bearing and clutch disc) sabi babalik din daw sa normal un clutch pedal. nasira at pinalitan ko na un master clutch cylinder and slave kit ganun pa din.
Clutch problem
