Results 1 to 6 of 6
    Aug 2014
    Hi Tsikoters,
    Any idea what could be the problem why AC Compressor does not engage. A quick google said that prossibly its due to freon under pressure or relay busted, but any one here have actual experienced on your Isuzu Highlander or similar, so it can help for DIY check before going to expert paid AC tech?
    Thanks in advance.
    Aug 2004
    Car AC systems are similar across most brands.
    Check the pressure switch plug on top of the dryer and the plug on the compressor itself. Minsan it's something as simple as a loose connection.
    Kung ok naman no choice but to go to the shop to have it pressure checked. The compressor won't engage if the pressure switch detects that the system pressure is above or below a certain level.
    ubos na freon, meron butas
    busted relay
    magnetic clutch
    a quick visit to a A/C shop will tell you more even w/o them dismantling everything
    most AC shops have FREE Check-up ... go na
    if you want a quick check whether yuor AC still have freon ... while the engine is off, press momentarily any of the freon valve pins, if freon leaks, then you have freon, and most likely pressure switch is the culprit
    Jan 2014
    Quote Originally Posted by aioshin View Post
    Hi Tsikoters,
    Thanks in advance.
    Pacheck mo muna AC shop like Frigidzone kung
    palitin na compressor palitan mo na
    10k yung compressor nung XUV ko sa CASA
    siguro naman mas mura sa labas ng 50%
    Aug 2014
    Tsikoters,
    Really thanks for all the reply, I found the culprit, the fuse intended for the cooler busted, I dunno though why it was busted, but should not be a short, because I already used it whole day and still ok, so probably a spike of current and thanks for the fuse, it save what it should save. Now, its ok.
AC Compressor does not engage - AC not cooling.
