Results 1 to 10 of 13
July 1st, 2014 04:22 PM #1
mga sir yung isuzu trooper (4jg2) ko po matagal mag start pag malamig ang makina, mga 5 click muna bago mag start ang makina. makalas naman po redondo. at kung napa andar ko na at na park ko na sa mall kahit 5hrs madali nman mag start. yun lang tlaga problem nya sa unang start hard starting talaga. kahit tanghali ako mag start matagal parin.
Posted via Tsikot Mobile App
July 1st, 2014 04:47 PM #2
July 1st, 2014 04:48 PM #3
What's your fuel delivery system?
What year is your truck?
July 1st, 2014 05:01 PM #4
July 1st, 2014 05:05 PM #5
July 1st, 2014 05:17 PM #6
Have compression check done. Remember, if it is diesel, combustion relies on the heat of compression.
Posted through phlpost.gov.ph
- Jan 2008
- 4,726
July 1st, 2014 05:25 PM #7mas malamang yan weak glow plugs.. either the glow plug itself or the connections / relays..
pwede din may singaw yung fuel line mo at may hangin pag matagal na nakahinto..
yung dating isuzu C-190 na makina namin loose compression na, mahina na din ang oil pressure pero 1 click pa din sa start up
July 1st, 2014 06:07 PM #8
July 1st, 2014 06:40 PM #9
ang glow plug yan ba yung parang spark plug? yan din yung sinabi ng kaibigan ko na bka glow plug daw. last week dinala ko sa isang shop na malapit lang sa bahay namin ang ginawa lang nya pinalitan lang yung belt sa makina kasi maluwag na raw hindi na maka charge sa battery pero hanggang ngayon kahit bago na mga belt ganun parin. binalikan ko sa shop sabi nman nya na bili muna ako voltmeter para malaman ko ang boltahe ng battery.
- Oct 2009
- 2,271
July 4th, 2014 05:53 PM #10
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
