Results 7,331 to 7,340 of 12125
May 24th, 2016 02:25 PM #7331
Sir i did not change anything or settings it just came out from the casa na pede sila manood sa likod na while navi ako sa front..ang ginagawa ko lang set ko muna yung tv or video then in front of head unit i press SRC or NAVI button to select an option pede naman sya sa akin ng ganun sir...baka ang ginagawa nyo sir ay mauna yung navi then saka kayo mag video or tv then nawawala na yung navi nyo, try nyo baliktarin procedure sir...katulad sa akin video or tv muna set ko then after mag navi ako...
Sent from my CHM-U01 using Tapatalk
May 24th, 2016 02:28 PM #7332
May 24th, 2016 02:44 PM #7333
ok i try ko (movie first then navi)... usually 1 at a time ko pinapagana kasi ako lang mag-isa (di ko pa na check ang sabay na pag gamit), but last weekend drive sa malayo, navi poi first then movie (usb) para sa pasahero ko, at yun na yun, pag balik sa navi sa front nawawala na ang movie sa likod.
thanks, i will update sa result.
May 24th, 2016 02:56 PM #7334
Hi all,
For our USB function sa video, may limit ba ang file size at 1GB ang pwede i play ? di ko mabasa sa manual na may limitation sa size.
Kasi sa 6 na full movie ko sa usb, 4 ang ok gumagana (video and audio) file size less than 1GB each, while ang other 2 files are more than 1GB (1 avi and 1 mp4) video lang ok but walang sound. All these files ay ok kung sa PC or sa TV ipa play.
Anyway i will try another file again na more than 1GB size.
Thanks.
- Feb 2016
- 95
May 24th, 2016 03:14 PM #7335
Mga sir,para saan po ba yang horn na yan?
Sent from my B1-A71 using Tapatalk
May 24th, 2016 03:41 PM #7336
Sa 17" max size without rubbing is 265/70/17 (using oem wheels)
Sa 20" 265/55/20 max offset 0
Anong unit? Sa LS/LSM max file resolution is 480p.
Sa LS-A alam ko 720p. Hindi rin naman high def yung monitor kaya no use ang 1080p videos.
Pinaka maganda .mp4 format, most of my videos work with that.
Para sa alarm/immobilizer:
How an immobilizer system works on Isuzu MUX LS-M - YouTube
- Apr 2016
- 211
May 24th, 2016 04:49 PM #73373.0 4x2 AT
363 kms
29 litters
363/29 = 12.51724 kms/l
FT to FT
- May 2016
- 39
May 24th, 2016 07:24 PM #7338
May 24th, 2016 07:44 PM #7339
May 24th, 2016 08:29 PM #7340
Thanks to MUX Boxer got my hood Lifter and most especially the MUX utility box
Sent from my GT-N5100 using Tapatalk
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
