Page 734 of 1213 FirstFirst ... 634684724730731732733734735736737738744784834 ... LastLast
Results 7,331 to 7,340 of 12125
    Dec 2008
    #7331
    Quote Originally Posted by Valentina2.0 View Post
    I have ask my SA, di rin nya alam. Can you possibly point out the settings? at Navi or sa USB function, but wala setting to change dun, or meron ba?
    thank you.
    Sir i did not change anything or settings it just came out from the casa na pede sila manood sa likod na while navi ako sa front..ang ginagawa ko lang set ko muna yung tv or video then in front of head unit i press SRC or NAVI button to select an option pede naman sya sa akin ng ganun sir...baka ang ginagawa nyo sir ay mauna yung navi then saka kayo mag video or tv then nawawala na yung navi nyo, try nyo baliktarin procedure sir...katulad sa akin video or tv muna set ko then after mag navi ako...
    Sent from my CHM-U01 using Tapatalk
    Dec 2008
    #7332
    Quote Originally Posted by pjV50 View Post
    i usually use this when shopping / day dreaming for tires
    Tire size calculator
    Yes sir pero di ba mayron syang effect sa ating speedometer reading? Kung bibilis ba or babagal parang ganun😃😃😃
    Feb 2016
    #7333
    Quote Originally Posted by john042776 View Post
    ok i try ko (movie first then navi)... usually 1 at a time ko pinapagana kasi ako lang mag-isa (di ko pa na check ang sabay na pag gamit), but last weekend drive sa malayo, navi poi first then movie (usb) para sa pasahero ko, at yun na yun, pag balik sa navi sa front nawawala na ang movie sa likod.
    thanks, i will update sa result.
    Feb 2016
    #7334
    Hi all,
    For our USB function sa video, may limit ba ang file size at 1GB ang pwede i play ? di ko mabasa sa manual na may limitation sa size.
    Kasi sa 6 na full movie ko sa usb, 4 ang ok gumagana (video and audio) file size less than 1GB each, while ang other 2 files are more than 1GB (1 avi and 1 mp4) video lang ok but walang sound. All these files ay ok kung sa PC or sa TV ipa play.
    Anyway i will try another file again na more than 1GB size.
    Thanks.
    Feb 2016
    #7335
    Mga sir,para saan po ba yang horn na yan?
    Sent from my B1-A71 using Tapatalk
    Oct 2015
    #7336
    Guys on our mux what is the acceptable computations of changing tires if i want to change what are the limit computations or acceptable conversion measurement kung 20" and 17" na mags.. ...mags and tires?😂😂
    Sa 17" max size without rubbing is 265/70/17 (using oem wheels)
    Sa 20" 265/55/20 max offset 0
    Hi all,
    Thanks.
    Anong unit? Sa LS/LSM max file resolution is 480p.
    Sa LS-A alam ko 720p. Hindi rin naman high def yung monitor kaya no use ang 1080p videos.
    Pinaka maganda .mp4 format, most of my videos work with that.
    Quote Originally Posted by hpv View Post
    Para sa alarm/immobilizer:
    How an immobilizer system works on Isuzu MUX LS-M - YouTube
    Apr 2016
    #7337
    3.0 4x2 AT
    363 kms
    29 litters
    363/29 = 12.51724 kms/l
    FT to FT
    May 2016
    #7338
    Quote Originally Posted by Civic_Racer View Post
    Meron din ako. Nilabas ko yang usb wire.. Yung iba nakaikot pa sa likod ng stereo.bali nakalagay na sa compartment
    sent from above
    Aside from USB, meron po ba video in sa likod or ilalim? Ayaw ko kasi mag tvplus kung nasa harap lang din ung wire ng tv in
    Oct 2015
    #7339
    Quote Originally Posted by boni_boy View Post
    No choice sa stock HU. Palit ka ng android hu from autolink or growl para malinis yung harap.
    Here's how I mounted mine. Inipit ko na lang para hindi masyado halata.
    Aug 2005
    #7340
    Thanks to MUX Boxer got my hood Lifter and most especially the MUX utility box
    Sent from my GT-N5100 using Tapatalk
All New Isuzu MU-X // Alterra Next Generation
