Mga kosa ano ba dapat check or palitan pag 100K na tinakbo ng XUV? matic. like suspension? injectors? etc. para may alternative besides sa casa... san pa magaling mag pa service?![]()
If you religiously perform the recommended every 5,000kms or 3 months PMS sa CASA, the items replaced every 10,000kms would be the same stuff you'd need to replace. As for underchassis et al, case-to-case yun as recommended by the attending technician.
I still strongly recommend that you have your 100k PMS at an authorized ISUZU dealer.![]()
Tnx sir.
I will surely bring my XUV to Isuzu plaridel for check-up. Sa aircon ba habang malamig HINDI na kailangan pa linis? 2 years na hindi naman nag loloko malamig parin...
sir highly recommended ko yang bmd isuzu plaridel! my odo reads 140k++.. so far ang naging problema ko nag leak na suspension ko and replaced it with gas types.(may audio setup kase kaya medyo mabigat ang likod hehe) yung exhaust mga first 10k ko naranasan ang problems. buti under warranty. pinadagdagan ko na lang ng flexible hose.
recent problem experienced radiator leak. yun lang. considering this is an 8yr old vehicle. xuv din.
regarding sa aircon hanggang 10 months lang ako pinapalinis ko na. mahirap na kaseng masiraan ng aircon. kahet malamig pa. lalo pa sir ngayon mainit.
other than those wala na akong ibang major repairs. kaya maintenance-wise sobrang tuwa ako sa unit namin.
100,000 kms? Can't remember what we had done. Think all we did was change the oil and check the suspension. Since the Crosswind has no timing belt or chain, there's really nothing to adjust... though we probably should check the valve clearances very soon. (now almost 150,000 kms)
+1 to ISUZU BMD.
As for the aircon system cleaning, it is recommended to have it cleaned (whether or not it shows any sign of losing cool or weakening air velocity) every 20,000 kms. Since your Crosswind has reached 2 years without cleaning, this would be a good time to do so.![]()
Change ATF, differential oil, coolant, Engine Oil & filter, adjust tapet valve clearance, air filter (if dirty)
Under chassis greasing, tire rotation.![]()
Hehehe! Wrong person. Si white xwind ata dapat natanong mo.
Nope, I'm not from Bulacan (actually from Sta. Rosa, Laguna) but I've heard of many revs of ISUZU Bulacan. If you're from that side of town, why not check their dealer..... you may just like their service too.![]()
nope sir! i'm from baliwag..pero may lot kame sa may cyberville. pero currently i'm here in qc. sa bmd plaridel galing yung unit ko and had pms there. super satisfied ako sa gawa nila kase i had pms also in inteco q.ave and here in commonwealth.. kaya medyo bmd plaridel yung pinakagusto ko. regarding sa aircon sa labas na ko nagpapagawa at nagpapalinis e. going rate is 1.5k to 1.8k hth
medyo naiinis ako sa xwind o ngaun..medyo malangitgit ang pang ilalim nya, naiingayan ako. san kaya pwede ipalubricate to?
