Results 1 to 15 of 15
    [SIZE=4]good day!!![/SIZE]
    [SIZE=4]mga sir need help about the key duplicate of my 2000 isuzu hilander xtrm, maipasok siya pero ayaw talaga gumana, nagpagawa ako ng bago sa MR.Q. kaso ganon din dalawang susi ang nagamit nila di talaga nag open ang lock (sa ignition)... ano kaya magandang gawin dito kasi medyo manipis na yong original na ginagamit ko. baka may alam kayong magaling dito... taga cavite po ako.[/SIZE]
    [SIZE=4]thanks in advance.[/SIZE]
    Feb 2005
    Teka, medyo naguluhan ata ako dun.....
    You still have your original key that cannot turn on the ignition? Or is it the doors? Or both? Then Mr. Q duplicated a key (I assume patterned to the original key you have) but also does not work? On the ignition? The doors? Or both?
    Clear this questions so we'd know what kind of help we could suggest to you.
    Oct 2003
    when you say ayaw gumana that means ayaw pumasok? or ayaw mag turn?
    kung gumagana sa door then may problem yung ignition mo.
    ipa-duplicate mo na lang mismo sa isuzu.
    Try doing this. Turn the steering wheel left and right to nudge the locking system and maybe you would be able to turn the key.
    Quote Originally Posted by 4JGtootsie View Post
    pwede rin yang suggestion na yan...
    yes sir, the original key wala naman problem doon, (okey sya sa doors at sa ignition.). the problem is the duplicate key na pinagawa ko. di maka bukas ng pinto at worst di talaga mag turn sa ignition.
    tagaktak nga pawis ko sa kaka turn left to right walang nangyari.
    Today 09:51 AMjames00112233Re: need help key duplicate!!!!
    sir mga magkano naman kaya pag sa isuzu ko mismo ipa duplicate?
    Subukan mong magpa-duplicate pa sa iba. Baka paltos ang pagkakagawa ni Mr. Q.
    Pero mas maganda kung sa Isuzu na nga. Hwag mo na isipin pa kung magkano. Importante, magkaroon ka ng duplicate key na gagana sa Isuzu Xtrm mo.
    O....di ba?
    Feb 2005
    I agree with chua_riwap. It's likely that Mr. Q wasn't able to get the right "curves" on the key.
    Since you still have the original key, check the KEY NUMBER engrave on it. That should be the plant's guide on the correct "curves" on your car. Cost? Yeah, it's the least you should worry kesa naman tagaktak pawis mo... But that should not be more than P1,000 I guess. Orig ISUZU key pa yun.
    yes sir nakita ko nga na may code pa original, try ko din pumunta sa casa para mag pa duplicate.
    thanks Benzmizer.
    *sboogie thanks sir.
    ura mismo nong nag pa gawa ako binalik ko agad refundable naman.
    bow ako sa tsikoteers!!!!!!!!!
    Feb 2005
    *Col_em: In behalf of those who posted to try and help you, you're most welcome. We (including you) are enthusiasts here.... helping others and helped by others.
    kung may resibo ka pa ng duplicate ibalik mo para palitan
    mali siguro ang pagkakagawa nung duplicate
    try mo rin ilubog ng husto yung duplicate tapos habang isinususi mo unti unti mong hinuhugot
