Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    [SIZE=3]My Isuzu pickup's speedometer sensor might be busted.
    Anyone knows where i can buy a cheap one?
    Isuzu sells it for P8,000. Medyo mahal for me. Do you think i can get a replacement?
    I have a 2003 Isuzu 4x3 pickup.
    I will still confirm if the sensor is really busted as soon as the mechanic checks it. I hope its a loose connection lang or something.[/SIZE]
    Mar 2005
    Try Walco in Banawe. They sell original and replacement parts for Isuzu.
    Wow, ang mahal. Sa Mitsubishi dealer, Php 5,000.00 ang electronic speedo sensor ng Pajero. And I thought it was expensive already!
    May 2004
    Mahal talaga ganyang mga sensor lalo ng brand new. try to look sa mga surplusan. wait mo post si 4jgtootsie or better try to PM him. me nakuhanan dati sya na engine ng jdm 4jg2.
    Saan ko maka bili nang surplus sensor?
    Quote Originally Posted by lasbac
    Lasbac,
    Try Rick his # is 7328878. Bro 4x3 ba pick up mo? Ano kaya makina niyan?
    4x2 d ko alam anong engine. Direct Injection 3.8 turbo, Isuzu 2003
    Jul 2003
    Ako nakabili ako sa banawe sa Lucky Two Motor Parts auto 59 banawe Ave. Q.C. Tel. 7117949. Brand new 2,500 lang. Pag tumawag ka sabihin mo ikaw yong bumili last year baka tagain ka. Kasi nong binili ko yan nagtanong ako kung meron silang malapit na branch sa south tapos binigay no. sa pasay presyohan agad ako ng 5K don kaya lang hindi nakahirit kasi sabi ko nakatawag na ako don sa main branch nila ganun ang presyo. Mahal talaga sa casa ganung ang presyo that time 7,500 presyo nila nong nagtanong ako. Sa walco nong nagtanong ako wlang stock ang presyo nilan 4.5K to 5.5K daw.
    Quote Originally Posted by nap123
    nap,
    tinawagan ko ang Lucky Two, and yes, may available sila, P2,800 for the isuzu pick up. hopefully genuine isuzu part ang sa kanila. wlang stock sa walco. will try to confirm if the speedo sensor is really the problem when the mechanic (from isuzu) checks the pickup. mukhang even the mileage meters (top and bottom) are not working. but yong dalawa daw not connected to the speedo. thanks pare for the info. really appreciate it.
    lasbac
    Jul 2003
    oo nga pala pickup pala yan pang trooper pala ang speed sensor na binili ko. pero kung ang transmission mo ay AW30-40LE the same lang yon.
    Btw, nap, did you buy a speedo sensor before? for the pickup or trooper?
    The isuzu's speedometer began to work today. Weird! Was supposed to have the isuzu mechanic check it sa weekend (outside job para hindi mahal). Baka cleaning lang ang kailangan. Will see if it continues to work. Can't explain what happened. Checked the fuses the other day and cleaned them but wla naman connection daw sa speedo.
    Can anybody guess?
    Jul 2003
    Can anybody guess?
    Oo bumili ako for trooper. Okay naman brand new sya parehas naman ang itsura niya with original. Siguro bibigay na ang speed sensor mo ganyan nangyari sakin knock on wood sana hindi.
    Speedometer acted up again last night, meaning it stopped. Will have it checked. Baka "cleaning" lang kailangan. Whats weird is that even the mileage meter stops when it stops. Can't explain it. Baka somehow connected.
    May 2004
    mileage meter is connected with the speedometer. yung civic ko ganyan dati. pag nagloloko, hinto lang ako ok na naman. after a while, bumigay din(same experience nung trooper nap).
    Had the mechanic check the speedometer sensor and gauges. Seems ok but speedo wont still function after the wires were checked, cleaned, etc. The gears attached to the sensor is ok (the isuzu has only 48k mileage). Will bring it to Isuzu shop tomorrow to try the sensors and gauage of the other fuego's to find out if it really is the sensor or guage thats a problem. The mechanic says it "might" be the gauge. I wonder how much that will cost. Electronic rin. Anybody know?
    Jul 2003
    hindi rin talaga gagana pati yong odometer mo kapag bumigay na ang speed sensor mo. Yung rpm mo diba gumagana yung sa speedometer at odometer mo lang ang hindi gumagana. its better pacheck mo nalang sa isuzu mechanic with know how to check the speed sensor.
    Changed the speed sensor after we tried other speed sensors from a fuego pickup. Bought one for P2,600. Ok naman. Speedo working fine now. Thanks all for your advices. Really appreciate it.
    Jul 2003
    No problem lasbac. Attend ka nalang ng EB sa susunod.
    Will do nap, when i'm in manila. Im from bacolod.
Isuzu speedometer sensor (Help!)
