Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Oct 2007
    Hi guys. Na-experience nyo na ba na parang may off odor (i.e., parang amoy ipis) pag binuksan ang aircon? My car is just 2 months old. Sa unang buga ng aircon lang naman aya amoy and then nawawala na after a few munutes.
    Have you ever experienced this? Ano kayang okay na gawin?
    TIA!
    Sent from my iPhone using Tapatalk - now Free
    Oct 2007
    I don't want to put car freshener naman since I want to maintain that new car scent. Bad trip lang talaga yung amoy ipis at first.
    you can grin and bear it and wait for it to disappear in a few weeks... puede rin kasing galing yan sa pandikit na ginamit nila...
    or, you can bring it to the fixit shop and they can look for the source.
    Oct 2007
    Thanks dr. d!
    evaporator needs cleaning
    Oct 2007
    Kahit na bago pa lang ang car?
    Quote Originally Posted by kinyo View Post
    Mar 2012
    Before ko turn off un engine and AC, set ko muna sa fan un AC para walang moisture build-up.
    Quote Originally Posted by mad0307 View Post
    TIA!
    That's the brand new smell. Or your cabin filter has charcoal imbedded on it. Kaya yun Ang naaamoy mo
    Sent from my iPhone using Tapatalk 2
    #retzing
    Oct 2007
    I brought my car sa casa. They just deodorized the filter. Okay naman sya but after a few weeks balik na naman yung amoy ipis. Hay! Ipa-change ko na kaya yung filter?
    May 2012
    Minsan maasim na amoy. Sabi nila wag daw
    mag spray ng perfume while inside the car.
    Feb 2005
    Try putting charcoal, baking soda, or dehumidifiers inside the car overnight. Ewan ko nga lang kung madadamay ung "new car smell".
    Any chance some perfume or anything similar was sprayed inside the car before that? Usually un ang cause e.
    Jul 2006
    Baka may ipis nga?
    Jan 2011
    It's common among brand new cars now. It's mainly due to the condensation that's left in the evaporator coils. What I do is that I turn off the compressor with the fan still running when I'm a few minutes away from my destination. This gives the evaporator a chance to dry out.
    Jan 2008
    gawa yan nung aluminum coil.. nag oxidize kasi yung aluminum kaya parang maasim ang dating... mawawala yan pag medyo nabalutan na ng carbon yung coil lalo na yung pag medyo umitim na.. since may mga cabin filter na mas matagal mabalutan ng carbon (dumi) yung coil, mas matagal na may amoy
    nangyari din sa akin yan.
    may mga tumutubong molds dyan sa loob ng tubings dahil sa moisture, tapos naguuulan pa.
    put your vent switch to the opposite of circulate. (dalawa yan.... circulate cabin, tsaka allow external air to come in. dun ka sa external air to come in.)
    put your blower direction to also allow external air to come in.... pagkatapos nung paa lang.
    turn off your compressor.
    leave it ng mga 5 minutes bago mo isara ang makina.
    do that everyday.
    after a week mawawala yan.
    lagay ka din ng charcoal sa loob. don't use perfumes muna.
    if the car is new just replace the the cabin filter. baka yan meron imbedded na charcoal...palitan mo ng regular na walang charcoal
    Jul 2011
    Ginamitan ko ng ABRO AC cleaner ung rav4, meron available sa concored sm southmall. Unang spray pinadaan ko sa AC drain then ung sumunod dun na sa center vent. Long term solution siguro ung bibili ako ng turbo timer pero i-tap ko sa AC blower para pag nag off ako ng car tuloy pa din ikot ng fan for a few minutes.
    Apr 2013
    ano po yung new car nila sir? may na encounter din kase ko na ganitong issue regarding sa new car ng isang particular model and brand..hindi ko lang alam if related or different situation..
    Nov 2011
    Quote Originally Posted by hachooro View Post
    this is true, i use to spray lysol violet to disinfect bacteria and viruses, but the after effect is a sour smell sa initial na pag turn on ng aircon... takes a long time para mawala ang amoy... after i stop spraying, the bad smell also stopped..
    Jan 2014
    baka naman may nag yoyosi sa loob ng car...or nabasa ang carpet mo kaya naiwan ang amoy asim
Off-odor when turning on the AC
