Results 1 to 4 of 4
April 22nd, 2009 10:08 PM #1
mga pipols...baka pwede mai-DIY...
how will one go about cleaning the inside instrumentation panel para maibalik ang kaunting liwanag ng mga peanut bulbs sa instrumentation panel...at para na rin malinisan yun dials/hands ng mga gauges (rpm, odometer, fuel, temp).? sympre, linisin na rin yun plkastic cover ng instrumentation panel.
car: 1999 honda civic vtec, all-stock
TIA
May 4th, 2009 02:19 AM #2
I did a DIY on my car's gauge. not a civic though but its most likely the same for your car.
here are the things you need:
plastic polish, philips and flat screwdriver, microfiber towel, 6-8 peanut bulbs, lens brush (optional)
1. remove the screws holding the gauge bezel, check for other screws that need to be removed then pull out the bezel.
2. remove the screws holding the gauge, then pull out the harness.
3. with a flat screw driver, unhook the tabs holding the gauge's clear plastic lens.
4. apply plastic polish on both sides of the gauge's lens, let it dry then buff. repeat if necessary. clean the dials using a lens brush.
5. remove the old peanut bulbs and condom and place it on the new bulb.
6. reinstall the lens, harness, etc and enjoy having a neat looking gauge.
May 5th, 2009 05:16 AM #3
*non-vtek: i can see that you drive a cefiro from your icon. please join us at cefiroclub.tk- speednuts420
How about 97 LXi?
Civic horsepower
