Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Aug 2012
    Hello po mga tsikoteers.
    May question lang po ako regarding sa quality ng engine oil for accent crdi.
    Base po kasi sa nakalagay sa manual, ang required na engine oil quality is at least API CH-4 or ACEA B4
    So naghanap po kami ng engine oil na may ganyan specs, ang nakita ko lang po na available that time is Kixx Turbo RV (API CI-4, ACEA A3/B4).
    Ang price po ng kixx is 1700 for 6 liters sa banawe.
    Medyo pricey nga po compare sa regular diesel oil.
    Sa mga owner ng accent crdi, anong engine oil po ang gamit nyo?
    Sinusunod nyo din ba yung engine oil requirements ng manual?
    Ok lang din ba na ang gamitin na oil is regular API CF-4 tulad ng Shell helix hx5?
    May magiging problem ba sa engine kung regular oil lang ang gamit?
    Balak din po kasi na gawing taxi yung accent namin.
    So i just want to make sure na it wont affect the engine kung sakaling regular oil lang ang gagamitin namin for business.
    Sa mga tsikoteers na may taxi business, any kind of advise po would be appreciated.
    Thanks po in advance!
    better follow the API rating. madami naman na CH-4 or above na oil. and reason kung bakit kailangan ng CH-4 or above is becuase of the EGR valve. and using of better oil will prolong the turbo life. please correct me if im wrong here.
    mga nagamit ko na oils na CI-4 rated ay:
    Top1 Synthetic Diesel Oil = 260-300 pesos per liter
    Zic Up semi-synthetic oil = 220-250 pesos per liter
    parehong semi-synthetic yan. and both are good quality oils. antayin natin yung comments ng ibang gurus dito.
    Aug 2012
    thanks crazy_boy for the tip! ive heared na mahal nga ang turbo kpag nasira so it make sense din to use the right oil.
    let see kung anong opinion ng ibang gurus dito.
    thanks din for sharing the brand of oil and price na gamit mo.
    base sa price range mas mura nga kesa kixx.
    would you mind sharing kung san ka kumukuha ng top1or zic oil? thanks!
    Quote Originally Posted by toto7 View Post
    yung Top1 sa suking auto supply meron
    Aug 2006
    Ang pinapagamit ko ngayon sa mga medrep naming naka Accent & Getz CRDI yung Seaoil Deo Max 15w40 CI-4. OK naman ang performance niya. Kung gusto mong subukan nang isahan muna, nasa 160-180php/liter pero mas mura pa kung bulk. Kung kaya ng budget, bili ka rin ng mas magandang filter para ma-extend mo yung interval hanggang 8k km.
    Oct 2011
    Quote Originally Posted by Revenant View Post
    mura na yan tapos API CI-4 rated pa.
    Aug 2012
    Thanks po sir revenant!
    mura nga yan seaoil deo max at api ci-4 pa ang rating.
    synthetic po ba yan?
    i think ok padin kahit hindi synthetic basta ang important is tama ang api rating at on time ang oil change?
    san po kayo nakakakuha ng bulk order for your fleet? thanks!
    Nov 2011
    Try niyo yunh isang klase ng ZIC. CJ-4 rating siya.
    Aug 2006
    Group II mineral oil ang DEO. Nandito yung specs:Seaoil DEO Max. Heto naman yung contact numbers sa corporate office nila: Contacts.
    Bumili ka na lang muna ng mga magiging test sample niyo bago ka mag-decide kung ano na ang gagawin niyong official engine oil. Nasa 660php/4 liters yung DEO Max sa ibang Seaoil stations. Yun namang Petron Rev-X Trekker CI-4 nasa 180-200php/liter.
    Aug 2012
    Salamat Revenant for the info! Malaking tulong ito.
    Try namin to contact their office to inquire for bulk orders.
    At tama nga mas mabuti matest muna maige ang oil bago kami magstock. Thanks for the reminder!
    Check din namin yung Petron Rev-X Trekker.
    Quote Originally Posted by jdee12 View Post
    Kaso gagawin na daw niya taxi yung accent niya. Sayang naman kung cj4 na gagamitin. Ch4 lang naman minimum requirement ng engine niya
    Nov 2011
    Hehe, oo nga. Over qualified ang CJ-4.
    Aug 2012
    May point ka pre, sayang nga kung cj4 ang gagamitin namin dahil over qualified nga katulad ng sinabe ni jdee12.
    Aug 2012
    Anyway, since gagawin pang business yung accent, i think it make sense to go for cheaper alternatives.
    As long as tama ang oil rating kahit hindi synthetic at basta on time ang oil change interval, i think dapat walang maging problem.
    Sa mga kapatid natin dito na may taxi business, i hope mabasa nila itong thread at makapag bigay din ng kanilang input.
    Yung Caltex Deo 400 Multigrade (CI-4) at Castrol GTX Mineral (API CH-4) ok din po ba for accent?
    Sa mga naka gamit na kamusta naman ang quality at magkano ang price?
    Thanks po!
    Thanks po!
    Id rather use Delo kesa castrol. Pero mas mabuti basa sa dito sa tsikot. May 2 thread na pinaguusapan about oils and oil filters
    Jun 2011
    Hi Sir
    If you need parts for accent, meron store aku sa pasay named Excel automotive and industrial sales. Malapit sya sa edsa taft station.
    Aug 2012
    Quote Originally Posted by yugregory View Post
    Hi Sir
    Hi ygregory, pm mo naman sakin contact number of your store para matawagan namin just in case. Thanks!
    Zic RV is CI-4. FS as well. Definitely better than the CF HGMO is rated as.
    Aug 2012
    Saan po kayo kumukuha ng zic oil?
    Puro walang stock po kasi yung mga napagtanungan namin noon. Thanks!
    Mas okay yung Zic Up. 10w40 vs 10w30 ng RV. Better for our climate. Si miko101320 ng tsikot i-PM niyo, nagbebenta ata sya zic.
    Pero mas okay pa din Delo 400, CI-4+ rating niya.
Hyundai Accent CRDi Diesel Oil
