Results 1 to 10 of 19
- Oct 2008
- 259
July 29th, 2010 05:56 PM #1mga sir ask ko lng kung may idea kayo sa problem power
08crdi starex/ manual transmission.
pag nasa nlex or pag naka rekta then nag low gear ka na nawawala yung power nsa 2rpm na lang pag nag turn off ako then start again ok na ulit power then later on lost power na naman 2rpm lang
nag pa change oil and check up ako sa wheels wala naman daw problem, then papunta yung starex sa subic nag lost power na naman sa nlex and sctex...turn off then turn on yung engine ok na ulit
need advise thank you
July 29th, 2010 05:58 PM #2
[SIZE="4"]REMINDER: do not post in SMS/TXT shortcut format.
Read the rules.
Ignorance of the rules is not an excuse.
Repeated offenses will lead to banning.[/SIZE]
July 29th, 2010 06:01 PM #3
The problems sounds like the engine going into "safe-mode".
Maybe a fueling problem?
Injectors or fuel filter condition?
- Oct 2008
- 259
- Oct 2008
- 259
July 29th, 2010 06:07 PM #5
- Jul 2010
- 81
July 29th, 2010 08:12 PM #6Sir i suggest ibalik mo sa casa na binilan mo kasi under warranty pa siya and let them solve the problem
- Jul 2009
- 2,618
August 2nd, 2010 11:04 PM #7try nyo po yung fuel filter.
dati sa nanay ko starex crdi gradual loss of power hanggan namamatay na makina ng tuluyan. after a minute or two of waiting aandar nanaman sya uli only to repeat the entire cycle again after just a few kms.
it was contaminated fuel resulting to a clogged fuel filter so after 2,000 plus pesos, a new filter and draining the fuel tank ayos na uli sya. hth
p.s. binasa ko po uli yung symptoms. try nyo din pa-check yung variable geometry vanes ng turbo baka for some reason di bumubukas consistently kaya may loss of power po kayo
- 52,698
August 3rd, 2010 01:30 AM #8try the fuel filter. what is your mileage now? i plumb forgot to replace mine after over 39K. my engine would cut off when i tried to rev her..
August 3rd, 2010 08:49 AM #9
I encountered the same thing with our old 04 GRX TCi A/T (Gen3) back in 2005 while hard driving it along Marcos Highway going up to Baguio.
I think your ride is going into limp mode... RPM can go no higher than 2000 and there is definitely a huge loss of power.
In our case the "check engine" idiot lamp lit up... I turned off the engine after idling it for some time and then turned it back on... I did not encounter any similar problem after that...
My gut feel,- have them check your ECU, bro. It could now be intermittent...
10.5:band:
- Oct 2008
- 259
August 3rd, 2010 09:43 PM #10thank you sa mga advise... 31thousand plus kms mileage
p check ko ulit bukas baka nga fuel filter or yung pedal sensor daw, limp mode
post ko pag ok na sya
just seen a 10th gen cross 200,000 miles on reddit. is this a unicorn or has the cvt been proven...
All New 2016 Civic
