Results 1 to 10 of 1948
June 9th, 2007 08:32 AM #2
Good day peeps! I don't know if it could be of help or not, but am posting some of the STAREX's Technical Specs which I found on the Owner's Manual. By the way, my horse is a 2004 TDI.
MEASUREMENT:
for 9-seater
Length: 4695 mm
Width: 1820 mm
Wheel base: 2810 mm
Tread (Front): 1570 mm
Tread (Rear): 1545 mm
for 11 seater
Length: 5035 mm
Width: 1820 mm
Wheelbase: 3080 mm
Tread (Front): 1570
Tread (Rear): 1545
FUEL TANK CAPACITY: 65 liters
ENGINE TYPE
For Engine Type D4BB
Total Displacement: 2607 cc
Compression Ratio: 22
Firing Order: 1-3-4-2
Injection: ATDC 5 deg.
Idle speed (RPM): 850 +/- 100
For Engine Type D4BF (T/C)
Total Displacement: 2476 cc
Compression Ratio: 21
Injection: ATDC 7 deg.
Idle Speed: 750 +/- 100
For Engine Type D4BH (TCI)
Injection: ATDC 9 deg.
For Engine Type D4CB (TCI)
Total Displacement: 2497 cc
Compression Ratio: 17.6
Idle Speed: 800 +/- 100
ELECTRICAL
Battery: 12V-90AH MF
Generator: 12V-75A/110A
Starter: 12V-2.0 kw (MT), 2.2 kw (AT)
Bulb Capacity:
Headlight, upper / lower beam: 60/55W
Front turn-signal lamps: 21W
Position Lamps: 5W
Rear turn-signal lamps: 21W
Reversing lamps: 21W
License Plate lamps: 5W
Stop and Tail lamps: 21/5W
Front Fog lamps: 55W
Side repeater lamp: 5W
Rear Fog lamp: 21W
LUBRICATION
For 2.6, 2.5 4D56 TC or TCI (API CF-4 or Above)
SAE #30 (Above 0 deg C)
SAE 20W-40 (Above -10 deg C)
SAE 15W-40 (Above -15 deg C)
SAE 10W-30 (-20 deg to 40 deg C)
For 2.5 CRDi / TCI (API CE or Above)
SAE 30 (0 to 40 deg C)
Engine Oil Consumption
Normal Driving Condition: Max 1L/1500km
Severe Driving Condition: Max 1L/1000 km
Transmission Oil
Manual: Hyundai Genuine Parts MTF 75W/90 (SPI GL-4)
2.6: 2.0L
2.5 4D56 TC or TCI: 2.4L
2.5 CRDi TCI: 3.2
Automatic: Diamond ATF DEXRON II, DIAMOND ATF SP I
2.6: 8.5L (11 seater), 7L (9 seater)
2.5 4D56 TC or TCI: 8.5L
2.5 4D56 TCI Euro III: 7.53L
2.5 4D56 TCI (4WD): 9.83L
2.5 CRDi TCI (2WD): 8.3L
2.5 CRDi TCI (4WD): 11.7L
Transfer Case Oil:
DIAMOND ATF SP II; 1.3L
Power Steering Oil:
PSF-3; 0.8L
Coolant:
High Quality Ethylene Glycol Base for Aluminum Radiator: 10L
Clutch and Brake Fluid:
SAE J 1703 or Equivalent; Quantity as needed
Front, Rear Wheel Bearing:
SAE J310a, MULTI-PURPOSE GREASE NLGI-2 or Equivalent; Quantity as needed
Rear Axle:
API GL-4 (MS517-15); SAE 90, 140; 2.6L
Steering Gear Box:
API GL-4 (MS517-15); SAE 80; Quantity as needed
Miscellaneous:
For TC and TCI engines: Required idle time before shutting off engine
High Speed Driving of up to 80 kph: +/- 20 seconds
High Speed Driving of up to 100 kph: 1 minute
Steep mountain slopes or continous driving in excess of 100 kph: 2 minutes
Recommended Tire Pressure for Tire Size:
195R 14C-6PR: 40 PSI
205/70R 15: 40 PSI
214/80 15: 32 PSI
Thanks all.
- Dec 2006
- 33
June 10th, 2007 09:49 AM #3Pa scan naman or post ng link for the Owner's Manual ng Starex '99 model. 2nd hand yung sa 'kin & wala ng manual. TIA
June 10th, 2007 01:44 PM #4
Hi guys,
Can someone tell me their fuel consumption of the new Starex CRDI vs the older turbo starex?
June 10th, 2007 04:43 PM #5
June 10th, 2007 07:19 PM #6
June 10th, 2007 01:54 PM #7
Thread was made nung 2018 pa po sir.
