Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Jan 2019
    Mga paps paano po pag tanggal ng wheel cover? Pasensiya na po new car owner here. TIA
    Sent from my SM-J730G using Tapatalk
    Quote Originally Posted by nikkol View Post
    hindi naka-saad sa howner's manual?
    let's see...
    make sikwat it out, using a cloth-covered manikwat. the tire wrench the car came with, should suffice.
    or, manually pull it off, if you have space for your hands/fingers.
    older cars have two holes at the edge of the cover, where pulling prongs can be inserted and pulled...
    google it, po.
    or, as my officemate quipped,
    "i-daan mo ang kotse sa lubak, then brake a little and watch where the cover goes as it rolls to overtake you.
    mahirap talaga, that first time.
    good luck, po.
    Jan 2019
    let's see...
    google it, po.
    good luck, po.
    Hehe sinubukang ko po yung sa lubak, di po natanggal haha. wala po sa manual how to do it.
    gugol nyo po.
    the first time, it might feel as if may mababasag o ma-crack. but it won't.
    ikaw talaga dr.d, baka masiraan pa ng pang ilalim si TS hahaha
    Apr 2014
    Naka lugs ba ang wheel cover?
    Otherwise, a generous amount of pull force is needed.
    As what dr. d mentioned, make sikwat sikwat first.
    Jan 2019
    Quote Originally Posted by chronicle View Post
    Yes po may lugs pero diko alam kung totoo or part ng design lang. Try ko po send ng picture dito
    most of the time design lang yan.
    try mo nalang magbaklas ng wheel kunyari na flat tire ka. so under duress mahihila mo yan for sure
    Jan 2019
    Hehe cge po try ko yan sir, sana si masira. Send sana ako picture dito di ako maka upload. Salamat po sa mga nag reply laking tulong po for a newbie like me.
    Accent owner ako. Kailangan mo tanggalin yung lug nuts. Ibig ko sabihin, kailangan mo i-jack up yung auto mo kung tatanggalin mo yung lug nuts.
    Di na kailagan i jack yan. Pwede ka naman magtanggal ng lug nut ng di naka jack. Ang tatanggalin lang naman ay cover, di naman gulong.
    Quote Originally Posted by Super Inggo View Post
    Uhmm... ginagawa mo ba talaga yan? So tatanggalin mo lahat ng lugnuts tapos tatanggalin mo yung wheel cover tapos hihigpitan mo na yun lugnuts?
    Unsafe practice plus you will damage the stud and rim-lugnut hole. The weight and torque should be distributed on the chamfer of the lug-nut an rim-hole.
    Proper way is to lift the weight of the hub by jacking-up thereby removing the tension on the stud, undo the nut, remove the cover.
    Jan 2019
    Sir, yung lug nuts ng cover tunay yun or design lang? So tanggalin ko lug nuts para matanggal cover? Thanks
    Jan 2019
    Sikwatin no sir will do it.
    Jan 2019
    Baka sa youtube sir meron tutorial.
    why do i have this feeling, that we are thinking of two different "wheel covers" ?
    i tried googling, but i got nowhere.
    i have always thought, we just pull it off.
    note that some taxis have plastic pull ties to prevent their wheel covers from running away.
    Jun 2012
    Iba ang accent sa mga wheel cover ng ibang sasakyan na patong lang na pwedeng lumipad. Sa accent nakakabit sya with the lugnuts
    Jan 2019
    Quote Originally Posted by dct View Post
    So I need to remove the lug nuts of the cover sir? Thank you po
    Jan 2019
How to remove wheel cover of Hyundai accent?
