Results 1 to 12 of 12
    Feb 2007
    Mga Ka-honda patulong lang po. Bago pa lang sa akin oto ko... 96 vti. eto nagiging problem ko ngayon:
    After about 15-20 minutes of driving, may lumalabas na lagutok/langitngit sa may bandang left side. Ramdam sa steering kung minsan. At first my suspect is the suspension but then the puzzling thing is bakit hindi agad lumalabas? And the suspension arm is relatively new pa naman. And the shock absorbers are also new. Could it be the rack & pinion or anything within the power steering system? Parang may slight na kabig din kasi eh to the left. Pagka-park ng oto at inalog ko yung harap, lumalabas yung sound. Pero pag malamig na ulit ang makina, say after about an hour, wala na yung sound.
    Baka meron sa inyong naka-experience din nag ganito. Your inputs will be highly appreciated.
    Thanks.
    Aug 2007
    Sir try mo patignan yang PS mo. Di po ba nagbabawas ng PS fluid?
    Check the suspension's top mount. There is a rubber bushing there that might have worn out and might need replacing already.
    Feb 2007
    will do that sir. thanks... though yun pong concern ko is why does the problem appear only after about 15-20 minutes of driving.
    Feb 2007
    Quote Originally Posted by vici0us View Post
    ino-obserbahan ko po sir ngayon kung nagbabawas. so far non-conclusive pa since mga 3 days pa lang yung problem.
    Dec 2009
    Quote Originally Posted by manley View Post
    Thanks.
    sir, try nyo check yung shock mounting. You also said new yung suspension arm nyo, but have you doubled-check yung part duon that houses the bushing? try nyo rin tingnan baka worn out na.
    Feb 2007
    Quote Originally Posted by smallville68 View Post
    thanks sir. will check that too.
    Jul 2010
    Try mo stabilizer link sir
    sir try to check tie rod end. ganyan din sa akin dati. wala nang grasa ang ball sa loob. natuyo na. kaya pag umiinit na ang makina umiingay na sya. pag malamig pa makina at kung naulan at malamig ang panahon walang ingay.
    Feb 2007
    Quote Originally Posted by D15B View Post
    thank you sir... will check that.
    Feb 2007
    sir, bullseye po... eto nga problema. napagawa ko na. thanks.
Tok tok sound/rattle after 15-20 minutes of driving (CIVIC VTI 96)
