Results 1 to 20 of 50
    mga bro bakit kaya yung 96 lxi ko nag-wiwiggle kapag nag pepreno ako?
    ang lakas ng alog eh, lalo na yung manubela kapag mabilis takbo tapos magpepreno ako ng konti.
    Feb 2010
    boss try mo pa check brakes mo... malamang kelangan na palitan di na pantay ang kagat.....
    Quote Originally Posted by cjtjamandra View Post
    Check your tie rod ends, pitman arm for play. If there is no play at all then you might want to have your 4 wheels balanced.
    Quote Originally Posted by reym View Post
    Bale yung tie rod ko daw dapat ng palitan pati yung axle boot. Yun pala reason nun pag wiggle.
    Bro may recommended shop ka ba within QC?
    Mar 2005
    Baka warped na yung rotors ganyan din sa lancer ko dati after palit ng rotors nawala an alog.
    Quote Originally Posted by jmpet626 View Post
    Brod ano pala itsura nung rotors? mga magkano nagastos mo dun at saan ka nagpagawa? Thanks.
    Google for Zee or Cruven.
    After replacement, you should have your steering components aligned and have your wheels balanced.
    You should start with this solution since the fault is already obvious.
    Sir ito rin ba yung reason kaya masyadong ma vibrate yung tsikot ko?
    Masyado kasi vibration, naaano yung tenga ko, yung parang may tubig sa tenga. pero hindi naman maingay.
    Oct 2009
    change your rotors and sabay mo narin disc pad
    Jul 2010
    Hi sir,
    If you step on the brakes and you feel that the brake pedal is pulsating then it is most likely the rotors at the front wheels. If its not, it could be the tie-rods or any of the suspension components.
    Cheers
nag-wiwiggle kapag nagpepreno
