mga bos ok ln ba sa crv 2.0 na sagad sa advance ang ignition timming?
no.
malakas sa gas pag sobrang advance sa timing. 5 degrees advance nga lakas na sa gas (pero malakas ang hatak in my observation).
why would you need to manually adjust the timing anyway?
the stock settings and valve gaps (7 in 11 ex yata) are fine.
salamat bos meronn kasi kakaibang vibration ako nararamdam at uneven idling.
since first gen pa yan bro.. i guess madami na din issues yan like my old eg. a bit advance na din ang timing ko since hirap sa arangkada at tumutope pag naka retard or default timing.
adavnce mo lng ng konti tas test drive mo... i wont hurt much nman if u advance it a little.. cars are like human they grow old...
No, it would mean something is wrong with your engine.
I strongly recommend to have the source of the vibration/uneven idling figured out than simply to hide it.salamat bos meronn kasi kakaibang vibration ako nararamdam at uneven idling.
It might be a vacuum leak or a faulty sensor. Or it could be something else like a defective sparkplug wire (leak), etc.
I suggest to have your car brought to a trusted auto shop for a proper diagnosis.
salamat bos baka dalhin ko na lng sa honda dasmarinas.
dati kasi parang mamatay pero ng sinagad ko advance naging okay naman at lumakas ang hatak. pero nagkaroon ng kakaibang vibration pag nakaminor lng ramdam mo sa flooring.
anybody know or have a video link on how to open the map lights?
i would like to change the map lights from yellow to white.
