Results 1 to 7 of 7
- May 2010
- 13
July 27th, 2010 02:41 PM #1tanong ko lang kung bakit kaya ambilis mangitim ("darken") nung oil ng '96 LXi ko
just had it changed sa Honda Shaw (casa) last May and nasa 2,500kms pa lang tinatakbo ko since then.
just last month, medyo brownish pa kulay nya pero pag-check ko last weekend, maitim na. normal ba yun for Honda (OEM) engine oil?
July 27th, 2010 03:12 PM #2
Tol , Kung mabilis mangitim iyong oem Honda motor oil mo ibig sabihin lang maganda ang detergent ingredient ng oil kaya magandang maglinis ng makina . Sundin mo lang iyong regular na change oil mo every 5,000 km wala kang magiging problema sa makina mo . Suggestion lang.
- Feb 2010
- 66
July 28th, 2010 09:29 AM #3
July 28th, 2010 09:49 AM #4
hondas generally don't make the oil black.
brown pa tas amoy gasolina (means you're overfueling a bit... try to adjust the idle speed).
gold and your oil is still good.
black means the oil could be oxidising too fast or your air filter needs replacing.
- Jun 2009
- 194
July 28th, 2010 10:06 AM #55000km sir? akala ko po pag honda at synthetic oil gamitin is 10000km? correct me if im wrong guys, just a newbie here...
tyvm
- Feb 2010
- 66
July 28th, 2010 02:17 PM #6
July 29th, 2010 09:21 AM #7
You can't tell the condition of the oil from just the color. You'd need to have your oil professionally analyzed for that.
i had mine replaced, but at the manila end. the las pinas end was closed at that time, kasi....
costal expressway
