Results 1 to 19 of 19
    Nov 2014
    Hello newbie po just want to know san pwede mag papalit rear bearing kse may humming sound ako pag 60kph sabi ng Honda Casa bearing replace naraw kaso ang mahal halos nasa 10k kasama labor grabe..... Bali 8.5k ata bearing at 1.5 laber
    San po kaya pwede na masmura magpagawa na ok naman at dapat po ba talaga genuine yun bearing????
    1k+ each Lang bearing a banawe, sa LVC tanong ka
    Feb 2005
    Yep mura lang bearing pati labor nito hindi naman super hirap ng tabaho, tattangalin lang ung wheel hub then palit bearing. Ggrasahan rin. Most competent shops can do the job.
    Nov 2014
    So this is replacement bearing po ba sir??? Grabe pala maningil Casa tsk tsk tsk.....
    Nov 2014
    Quote Originally Posted by kotiko View Post
    Sir yun sa wheelers sa banawe pwede po ba dun??? Dati dun ako nag papatira pangilalim eh....
    Ano po kaya bearing na brand maganda sir???
    Oct 2009
    kung rear lang simple lang yan basta may pang tanggal ka lang dun sa center nut 32 yata ung sukat nun.
    kuha ko sa wheel bearing is 1,2k each,ako nalang nag kakabit para maka tipid ng 500 na labor sa mekaniko
    pang inom nalang at pulutan ung 500 na natipid sarap..iminom pagkatapos mong magawa ung tsikot mo.
    Nov 2014
    Quote Originally Posted by jaypee10 View Post
    Ayuz!!! Ano model oto mo sir jaypee??? At san ka bumili ng bearing?? Ano brand maganda????
    Nov 2014
    Ok na napalitan na bearing sa likod....no more humming sound.....
    Wala pa 2k ginastos ko, kung sa honda casa almost 10k wew.....
    thanks Sa mga inputs nyo.....
    Jul 2012
    Quote Originally Posted by Arvin022274 View Post
    bro san mo pinagawa? need ko na rin paayos wheel bearing ko eh.
    Jul 2012
    Nov 2014
    Quote Originally Posted by nashimoto View Post
    Sa wheelers suspension sa banawe pre.....ok dun mura pa..... Yun bearing nasa 1.7k replacement bearing plus 200petot labor ok naman kse orig is nasa 8k sa CASA wala pa labor
    Nov 2014
    Jul 2012
    ilan pinapalitan mo? sakin kasi mukang isa sa likod lang.. need ba parehas palitan. problem ko hindi ako marunong mgpunta sa banawe. btw, sabi sakin iba ang wheel bearing ng mga sasakyan na may ABS. pag mali bearing daw kinabit mag iilaw sya sa dashboard.
    Nov 2014
    Isa lang pinalitan ko sa likod pre di naman kailangan dalawa.....alam nila yun dun yung sa ABS....
    Jul 2012
    ok na bearings ko.. unfortunately 2 pinalitan. sa minerva alabang ko pinabanatan kasi wala ako tym mag banawe.. 5k din inabot lahat lahat. nkpag tagaytay na kami.. kaso kagabi lang biglang nangnig makina ko.. from stop or idle lakas ng jerk pero kapag nkgas na ok na.. pero pag ni accelerate nag jerk nnmn. hinala ko ignition coils ko na ang may tama.
    Feb 2005
    Pinapalitan rin ba ang front wheel bearings ng City 04? I have a similar bearing noise and a driver told me it was the front bearing that's noisy and parang duon nga. I've only experienced replacing the rear ones.
    Jul 2012
    possible rin po ata palitan bearings sa harapan.
    Yup! Kailangan na press in press out for front wheel bearings.
    Feb 2015
    I have read good feedbacks about mel casaba. Mukhang sya dapat ang pinuntahan ko kaysa nagsayang ako ng pera dun sa huling mechanic ko. Im from valenzuela city pa. Kung okay sya talaga dadayuhin ko na. By the way i own honda civic vti-s 01, first time ko lang magtsikot kaya medyo onti palang ang alam. My problem is that after i release the break pedal may lumalagutok.(sabi mechanic normal?)
    Another thing, habang umaandar ako maingay sounds like (chug-chug-chug) parang nakadepende yung sound sa bilis ng andar. First the mechanic told me break pads daw. Then caliper kit changed. Then axle changed. But still ganun pa rin. Please help mga bro. Thrice nako naglabor wala naman improvement. Any suggestions please. Sorry haba ng post. Thanks
Honda City 2004 bearing problem help
