Guys, hirap mag start after ko ihataw yung hatch ko. Pinalitan ko na ng fuel filter. Fuel pump ok naman daw. I need opinion guys. TIA
Have you checked the ignition system for problems including the ignition coil?
original engine ba yan? ph12 carb?
if so, there could be a problem with your carburettor. nalulunod sa fuel kaya hirap mag start. or may singaw na.
have the carb overhauled muna... mura lang to sa kamias carb shops. tapos i-tune nila yung timing and then go to honda to get the valve clearances adjusted.
unless tumatakbo ka ng palyado, i don't think there's problem with your ign coil. maybe the spark plugs (fouled) or high tension wires meron ding biyak. these are worth checking na din while the carb is disassembled and you're just sitting there waiting.
sir.ipacheck mo ang ignition switch nyan.ganyan kasi naging prob sakin.ganun din pka start patay makina.
pwede din fuel pump or ecu relay.pwedeng ignition coil, spark plugs, distributor, high tension wire. try mo ipa tune up. mejo old na din kasi kotche kaya kelangan ng palit ng ibang pyesa.
isa isahin mo nlng i check lahat ng sinabi ko.makukuha mo din nman ang sira ng kotche mo.
GOODLUCK
Guys, thanks sa mga advice.
Ok na hatch ko, master relay yung prob.
Pero bago na ayos lahat nung mga sinabe nyo na check din.
Kala din namen nung una fuel filter, fuel pump, ignition coil, servo pero ok naman sila. Master relay pala.
Thanks sa lahat ng tumulong makaka tulog nko mahimbing.![]()
