Results 1 to 8 of 8
- Dec 2011
- 11
November 23rd, 2012 09:01 AM #1Hi guys, I've been reading these forums for quite some time and this is actually my first thread post. Have any of you tried Yokohama services? I've been planning to get my car checked since this car haven't checked for ages. They have this promo at Ensogo for Complete Wheel Alignment (TOE and CAMBER) + Free Preventive Maintenance at P699.
Details:
- The Complete Wheel Alignment is for the Toe and Camber.
- Preventive Maintenance
Included in the Preventive Maintenance are the following:
1. Break pads thickness on all 4 tires
2. Break pad operation on all 4 tires
3. Brake Rotor inspection on all 4 tires
4. Tire tread depth on all 4 tires
5. Front upper and lower ball joints on both front tires
6. Bearings check
7. CV joint check
8. Lube job for suspension and steering components (Gear Oil)
9. Lights operation (brake light, headlights, running lights, reverse lights, turn signals, dome light(s)
10. Windshield wipers, Windshield washer fluid, check Radiator fluid, check Transmission/ Clutch fluid, check Brake fluid, check Belt, check Leak, check Air filter, Check Tire Balance, check Alignment, Pre-requirement Check up - (Tire Rod, Rack End, Etc), Computerized Alignment Diagnosis - Front and Rear Tires Battery and Battery Cable Overall driveability (Test drive with mechanic/authorized personnel)
Also included are Free Nitrogen Tire Inflation and Tire Rotation
Any feedback on Yokohoma Malate, Manila Branch? Your replies will be highly appreciated!
November 23rd, 2012 10:35 AM #3
*TS, sir tanong mo naman sa Yoko kung magkano lahat kung walang discount
- Dec 2011
- 11
November 23rd, 2012 12:52 PM #5
- Aug 2009
- 42
November 25th, 2012 03:12 PM #6I.m planning to avail of this too on my SUV, but my is question is how do you know when is the time for your vehicle to undergo complete wheel alignment?
- Jul 2012
- 345
November 26th, 2012 05:32 PM #7wow ang mura! last time nag pa alignment ako it cost me 700+ sa minerva westgate dito sa may alabang. do they offer under chassis rin kaya?
November 26th, 2012 07:40 PM #8
sayang ended na yokohama promo * ensogo! request natin magkaron ulit parang 100 vouchers lang nabenta e. Sulit to at 699, ang camber/alignment usually nasa 2.5k, pag alignment lang 250... E yung promo sa ensogo may free nitrogen pa lahat ng gulong at tire rotation, pati greasing ng mga fitting free.
http://www.ensogo.com.ph/manila/yoko...-11122012.html
Always feel safe and secure by preventing accidents through a Complete Wheel Alignment (Toe and Camber) with Free Preventive Maintenance and other freebies.
The Complete Wheel Alignment is for the Toe and Camber. This and Preventive Maintenance improves your vehicles reliability and prevents costs of possible future repairs.
Also included are Free Nitrogen Tire Inflation and Tire Rotation.
Bearings check
CV joint check
Windshield wipers
Windshield washer fluid check
Radiator fluid check
Transmission/ Clutch fluid check
Brake fluid check
Belt check
Leak check
Air filter Check
Tire Balance check
Alignment Pre-requirement Check up - (Tire Rod, Rack End, Etc)
Free nitrogen tire inflation
Free tire rotation
Redemption period: November 28, 2012 to February 28, 2013.
Vouchers may not be combined.
Xiaomi E-Car
