Results 1 to 12 of 12
    hi guys! ask ko lang kayo kung bakit, pag pinipihit/kinakabig ko yung kotse ko pakaliwa o pakanan, di ba dapat babalik o iikot siya pabalik? yung sa akin. hindi na umiikot pabalik, kailangan mo pang alalayan..
    ano kaya ang possibleng sakit ng oto ko? magkano kaya aabutin nito? at saan ang ok na pagawaan para dito?
    salamat sa lahat ng mag rereply.
    Nov 2007
    What's your car Lloyd? I presume Honda is what you bought, possible culprit is the rack and pinion, it was tightly adjusted.
    Nov 2007
    ganyan din L300 ko
    Quote Originally Posted by ans_lim168 View Post
    Hi sir! Yes. Its honda. 1999 honda civic vti po. ganon po ba talaga sakit ng mga honda?
    Nov 2007
    Quote Originally Posted by lloydwena View Post
    Chances are the owner has adjusted the rack and pinion before, it is a cause for "kalampag", if you have the budget buy a new genuine rack and pinion for your ride for optimum performance (left and right). It cost around two thousand plus for one side so around five thousand to be sure, wala pa labor dito, plus you have to have a 4 wheel alignment afterwards.
    huwat! laki din pala sir! eto pa po pala, bumabalik naman siya, pero pag ung todong kabig, di na sya bumabalik, kelangan pang alalayan.. oks lang kaya na di ko muna ipa ayus?
    Nov 2007
    It's okay if you still don't have the budget to get it fixed, leave it as is but of course the sooner you get this repaired the better, plus the alignment of the vehicle is already compromised with the adjustment made by the former owner.
    Apr 2008
    rack and pinion na yan maganda nyan ipa-check mo na lang sa cruven yan tutal libre check naman dun at baka marepair na nila yan.
    pag naayos ang rack and pinion mo kelangan i-aalign mo pa yan kasi kung sa mga ibang talyer mo dadalhin yan na wala naman pang wheel alignment baka magka problema ka ulit.
    Quote Originally Posted by boy_tino View Post
    sa cruven po ba, lahat kayang gawin? and mga magkano kaya aabutin nun kung sakali?
    di naman po ba sya serious problem?
    Apr 2008
    subukan mong bisitahin ang site na'to
    http://www.cruven.net/
steering problem
