Results 1 to 14 of 14
    Jan 2011
    mga sir,
    went to baguio last weekend in my civic vti 96 AT, ok naman po ang hill climb until i reached the part in marcos highway where the climb was so long and my car couldn't keep up, i was only doing 20-25kmh, 2-3k rpm na nasa gear "2", todo apak nadin po ako sa gas pedal.
    anu po kaya problema ng kotse at anu solution? ok nmn po takbo ng kotse sa flats at hill climbs kung ndi lng mahaba. tnx
    Is this your first AT car sir? Yung overdrive button ba ay off or on? Dapat sa climb naka-off siya at sa downhill din na matagal.
    I also think tht you should have a mechanic from a reputable shop check your AT fluid if ok pa yung quantity and if puwede pa. Actually you can see (dapat reddish/pinkish and not brown or with bubbles) and smell it if burnt (bad) or not(good pa). Have it checked asap baka mas masira.
    Also, ok pa engine mo ha, no loss of compression or eating of engine oil?
    Aug 2004
    Quote Originally Posted by erebus_dynamics View Post
    mga sir,
    Did you try slotting it in "1"?
    Jun 2010
    wag mo ilagay sa "2" yung gear mo,,, dapat nasa D lang or D3,, kasi pag nilagay mo lang sa 2 yung gear ilolock lang ng trany yung gear sa 2, hindi niya ibababa sa 1 o iaakyat sa 3.
    Feb 2005
    How many passengers did you have? If you had at least 4, expected talaga yan from a gasser AT. But as niky mentioned, same as a MT, you should have shifted to 2 or 1 when you felt that the momentum going up slowed down drastically.
    I would not want to make you worry (immediately) that there is something wrong with your tranny if you felt there was nothing wrong for most of the travel. Then again, if your tranny is due for a tranny fluid/filter replacement and you have not done that, that may have a negative effect on its performance.
    May 2011
    Classic example ang sasakyan mo ng stuck piston ring. Dahil sa age ng car mo at hindi masyadong kagandahan ng motor oil sa Philippines, more than likely na sludge up na ang engine mo. Kailangan mong linisin ang loob ng engine at ang isang cleaner na maganda ay Auto RX. Ito ang gamit ko sa States at Australia. Meron itong seller sa PH at google/bing mo ang Auto Rx PH. Follow the instruction carefully. More than likely kailangan mo ng 2 treatment dahil sa age ng car. Para malaman mo kung effective ang Auto RX ay pa compression test mo before treatment and again after 1st treatment.
    Also, leave the transmission sa D. No need to turn on or off ang O/D.
    Talagang maraming gumagapang diyan sa stretch na iyan ng Marcos Hiway. Mahabang ahon kasi iyan....
    Wala ka bang nakitang mga trucks na nakahinto sa kalye at may kalang na bato sa gulong?
    Dapat, nasa D ka lang. Pagbalik mo sa Baguio,- you should try it again....
    13.6K:painting:
    Quote Originally Posted by 2gud4u View Post
    Had a '98 EK A/T before, and slotting the gear lever in "2" would make the transmission shuffle between gears 1 & 2, not locking the gear.
    Could point to another problem, perhaps?
    Jan 2011
    sorry for the late reply sirs, long weekend kc kaya natambakan din trabaho,
    Quote Originally Posted by mda View Post
    i think you have a point sir, since the only gear options sa honda civic 96-00 AT are P, R, N, D4, D3 and 2, 2 being the lowest gear using only the first and second gear, pero may OVERDRIVE MODE po ba ang model ng sasakyan ko? hehehe, noob lang po kasi.
    i think my car runs normally on the flat lands, i've tried running its VTEC and it works, or so i think it does coz its my first vtec, and i have reached a topspeed of 130KM/H.
    it was only me, my wife and our little boy riding when i encountered the dilemma and i'm still figuring out what the problem is. pakielaborate nlng po futher kung anu man po sa palagay nyo problema ng kotse ko. TNX
    I think that the 4th gear is the OD gear.
slow hill climb
