Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Sep 2013
    Hi guys I own a honda fit GD from japan with 120k na sa odometer.Kadalasan sa expressways dun nag bblink ang "D" then hirap mag shift na parang 1 gear lang.Hindi na rin pala smooth takbo ng GD ko pero walang malakas na jerk o nginig. Guys CVT na kaya to? Do you guys recommend buying surplus tranny kaya?
    Thanks po
    Nag try ka na ba magpalit ng oem na cvtf?
    I think it is starting to act up...
    Better have it checked, bro.
    21.5K:toothbr1:
    Sep 2013
    Sir robot, not yet boss i think hindi pa naman madumi yung cvtf pero dinagdagan ko siya last month. Na sosolusyunan ba ng change cvtf yang mga ganyan boss? Thanks boss
    Sir CVT, sabi sa honda spa hindi daw nababasa ng mga computer nila ang mga galing japan
    Try ko sa honda alabang boss
    Sep 2009
    Quote Originally Posted by Ciz View Post
    Thanks po
    Meron ng ganitong issue (CVT) dun sa isang thread ah (Second Gen Honda Jazz/Fit). Anyway, I'll share my wide experience on my GD-CVT.
    Twice na ako nagpalit ng tranny, first time ko naramdaman yung problema during our way home from Antipolo. While traversing the highway, bigla na lang nag blink yung "D" ko and then nararamdaman ko na humina yung hatak nya. Imagine, nasa 5000rpm ko pero ang takbo ko 30kph. I've decided to pull over in one of the gasoline station to check the manual while letting the engine rest. Nung start ko na, mejo bumalik sa normal condition so ang akala ko okay na but nag research pa din ako sa net ng preventive action and according to some GD owners, you just need to add/replace the CVT fluid, which I did. Almost 1 month wala ako nararamdaman na problema then suddenly, bigla na lang hindi gumana tranny. As in wala talagang abante, pero may reverse. I did everything to resolve the issue to wit; change oil, spark plugs, brake fluids and CVTF but to no avail. Dun ko lang nalaman na talagang wala na pag-asa kaya I've decided to replace the whole tranny.
    Second time, ganun din. Nag blink yung "D" and then nawawala din pag shut-off then start. After a week, ayun! itinirik ako sa gitna ng macapagal and buti na lang naramdaman ko dahil nasa third lane ako pero naitabi ko pa din sa gilid habang naka umaandar pa siya.
    Suggestion ko lang sayo. Wag ka lalabas ng bahay with less the 5-10k ang dalang pera dahil worse na pwde mangyari talaga sayo is itirik ka sa gitna at ma-tow and matiketan pa. Another thing, stop using the 7 speed mode dahil yun ang malakas makasira. Feeling mo nasa 2fast 2furious ka ba? He,he.
    Sep 2013
    Quote Originally Posted by wezz_zzew View Post
    boss medyo konti lang kasi reply dun hehe hindi masyado pinapansin.Sir 2nd owner na ako nakuha ko 120k ang odometer so ako naman maingat talaga ako sa kahit na anong sasakyan,hindi humahataw at di ko ginagamit yung 7 speed mode .Sir sa tingin niyo Tranny na talaga ito? and kung surplus tranny ba tatagal siya? or better change the car? kamusta na GD niyo sir. thanks for your reply sir
    Dec 2002
    ^ kung may budget siguro para peace of mind palit car ka nalang. pero just in case pa member ka na din sa AAP in case need mo ng towing mas mura.
    Sep 2013
    Quote Originally Posted by RC-V View Post
    nakakatakot naman to may budget naman sir hehehe kaso mabebenta pa kaya to ng 200+ i think hindi na dahil sa tranny
    Jun 2013
    Share ko lang, I own a Honda City Idsi.CVT din. iba nmn ang case. saken nakalog ang buong makina pag nasa reverse tsaka may jerking pag nakamenor. at minsan ayaw na tlga umatras parang bumibitaw ung reverse ko. Nagpalit ako ng tranny last month lang. sa banawe. okay naman. kung gsto mo pa isalba ung GD mo, try mo muna mag change ng Tranny fluid, pero kung gsto palita ng tranny. pwede din. Swabe naman ngayon ung takbo ng kotse.
    Sep 2013
    Quote Originally Posted by ditang View Post
    Sir ang hindi smooth na takbo,Blinking "D" could be solved by changing the CVTF lang?Wala pa ako ganyang symptoms sir. but diba tranny fluid change aabutin 3k sir? sir howmuch nga po pala ang tranny fom banawe and how much labor? Thank you sir
    Dec 2002
    nabasa ko sa kabila 35k daw tranny. basahin mo yung whole tread duon sa cvt problem.
    Sep 2013
    Ang rami kasi ng price na nakikita ko pinakamura is 20k may 28k may 35k haha ) thanks sir
    Sep 2009
    Try mo change ng CVTF fluid then monitor if there will be changes. Worse case, change the tranny with surplus from Japan. Dami sa Banawe but make sure na mapagkakatiwalaan mo yung seller dahil yung iba dun, nabaha nung mga nagdaang bagyo. Yung sa akin ok pa din naman hanggang ngayon dahil hindi ko na ginagamit yung 7 speed mode. FYI, once nagblink yung "D", tranny na talaga issue nun. Just make sure lang na lagi ka may extra cash at kaibigan na pwedeng tawagan anytime para hilahin auto mo. ^_^
    Sep 2013
    Sir wez. Since nung nagpalit ka po ng surplus tranny ilan na po tinakbo ng auto niyo and ano po pang maintenance niyo? Change cvtf every 20k?
    Surplus tranny means po ba na nagamit na rin ng mga gd from japan? Thanks sir wez
    Jun 2013
    Try mo mag fluid change, oo mga ganon mga 3k sguro aabutin nakalimutan ko presyo e. sa banawe din ako bumili ng CVTF, ung tranny nakuha ko ng 12k tas ang labor sknla 3k. pero kung me kilala ka na mekaniko try mo sknla kausapin mo nalang.
    Sep 2013
    ang mura ng kuha mo sir. ilang months na po sainyo new tranny niyo sir? ok pa naman? thanks po
    Jun 2013
    2 months na. okay naman. wala namang problema. ayos naman umandar. sama ka lang din ng marunong tumingin. pero okay kasi ung napunthan ko. don talga sila nakuha pati ibang shops. tas ang laban nila. hanggang di maayos ung tranny mo, palit lang ng palit.
    Sep 2013
    sir baka pwede po pa pm sakin name po ng shop sir saka baka may contact number ka boss. ty po
    Sep 2009
    Mga katsikot. Eto number nung kinukuhanan ko ng CVT tranny sa Banawe. 09326500881 (Sun), hanapin nyo na lang si Dado. Text lang pwede yung cellfone nyan kasi sira yata yung earpiece. Ask nyo na lang cia kung magkano na ngayon tranny plus labor. Nung kumuha ako nun dati nasa 18K lang kasama labor pero di yung CVT Fluid.
    Sep 2013
    thank you sir wezz! ok naman na po ang GD niyo sir? taga LP ka pala sir baka nakikita ko GD niyo hehehe LP rin ako eh.
    Mga boss add ko lang paminsan pag binibitawan ko ang gas parang nag bebreak siya bigla? parang may pumipigil bigla umandar? kasama ba to sa mga symptoms mga bossing?
Honda Jazz GD first Gen CVT?
