Results 11 to 20 of 23
- Sep 2013
- 153
October 25th, 2013 08:57 AM #11
October 25th, 2013 11:35 AM #12
- Sep 2013
- 153
October 26th, 2013 12:38 AM #13Possible ba un ang sira? kapag kasi jinump start ung kotse aandar naman agad. dala nga lang itulak, hehe. kung di lang hassle at nakakahiya hahayaan ko ng mahirap start kapag mainit ung makina, hahah. aantayin ko na lang lumamig, kaso hassle di ba layo kung nagmamadali ka, hehe
October 26th, 2013 01:46 AM #14
di ko sure pero based sa mga nababasa ko sa internet pag hard starting on warm engine mostly fuel related ung problema. something to do with vapor lock.
pero kung kaya paandarin pag push start malamang starter issue yan.
may kakilala ako na same problem mo. malapit na nya ipacheck sa casa. hehe balitaan kita kung ano diagnosis nung sa kanya ;)
October 26th, 2013 01:57 AM #15
http://autos.yahoo.com/maintain/repa...ques093_4.html
Hot starting problems can also be caused by cooling problems that allow your engine to run too hot (the pistons swell up and may scuff the cylinder walls), or excessive resistance in the starter motor that causes the engine to crank slowly. A starter "amp draw" test can be used to check the condition of your starter. Also, many starters have small "heat shields" to protect them from heat radiating from nearby exhaust pipes or manifolds. If the shield is missing, the starter may get too hot and bind up.
- Sep 2013
- 153
October 26th, 2013 12:23 PM #16Nageksperimento ako para maisolate ung problem. Sinubukan kong itakbo ng medyo malayo ung kotse para uminit ung makina tapos pinatay ko ung makina nung nasa average temperature na siya. Kaso di naulit ung problem. Sinubukan kong start ng ilang beses ung kotse para tingnan kung mauulit ung problem. Di pa din naulit.Buti na lang, sinubukan ko din na parang ikatease ung starter. Start ko pero di all the way. After mga 3 to 4 clicks, parang nadiskarga ung battery. So kumuha ako ng pangseries na cable saka battery galing sa isang sasakyan namin. Ayun nagstart siya. Inulit ko ung process. Kapag ung battery lang namin ng kotse mismo nauulit ko ung problem pero kapag nakaseries ung battery galing sa oner namin, nagsstart siya. So I guess, battery nga ung problem.
tama nga siguro ung napagtanungan ko nung una na mahina daw ung amperahe ng battery ko(dyna power). Balak kong palitan ng motolite enduro, medyo mahal din kasi ung motolite gold. hehe. Also considering outlast, kaso ala pa akong experience sa outlast. Maganda bang tatak ang outlast? Ung Motolite kasi subok na naman dati pa. hehe
- Oct 2013
- 7
October 27th, 2013 02:48 AM #17
- Nov 2011
- 79
October 29th, 2013 12:22 AM #18yung relay nakaturnilyo sa tabi ng fuse box..pero yung wiring mismo, ang alam ko sa ilalim dinukot..im just not sure about the where abouts..pag dinala mo sa auto electrical yan at sinabi mo relay para sa starter alam na nila agad... for recommendation, autoelectrical ko eh ke dongverz, located sya sa F. Manalo san juan, kung galing ka kalentong yung yung alternatet route pag pupunta k sa sta mesa at traffic sa v. mapa.. ang landmark nya ay ang intersection between mga papanik ng Dominican college(galing kalentong) pa-derecho, papuntang brgy sta lucia yata yung pakanan at yung pakaliwa ang F.manalo...paglikong pagliko lang sya sa kaliwa, andun na shop nya,,,ang mga katabi ng shop nya ay tindahan ng gulay,karne(semi talipapa)
- Oct 2013
- 7
December 10th, 2013 12:22 AM #19
- Sep 2013
- 153
December 14th, 2013 12:36 PM #20
Same design language across the range is fine Porsche, Audi, VW, Lexus and Mazda are all like...
China cars
