Originally Posted by
Egan101
You need not go to a Honda casa to change the brake fluid, if your car is out of warranty already. You cannot scoop out the brake fluid from its reservoir. Brake fluid is very corrosive and can damage your car's paint if you accidentally spill it over.
You can go to a trusted shop and ask them to bleed the brake fluid system and then replace the brake fluid. Just buy Honda OEM brake fluid from a Honda dealer (maybe 2 bottles will do) as Honda cars are quite choosy with fluids. Normal auto shops will not charge you more than 500 for the bleeding/replace of the brake fluid.
Since your car has reached 120k, you might as well change the ATF. Normal ATF change cycle is every 40k km. For more details, check your car's manual for what needs to be changed at 120k km.
